Trim switch on throttle
Old 07-15-2009, 12:23 AM   #21
jgreen's Avatar
jgreen is currently offline
Gallery Images: 2
Send jgreen:
Default Re: Trim switch on throttle
Originally Posted by Red Rover View Post
I took my throttle off and found that the wires leading to the back had corroded about a foot back on a connector piece. Hooked it all up and everything works great. Thanks for everyones help.
Another great idea, thanks. Next weekend I'm going on a corrosion busting day and clean everything related to the trim. Fingers will be crossed.
Jay
  • Old 07-15-2009, 01:53 PM   #22
    midwest mariah's Avatar
    midwest mariah is currently offline
    My Model: 1996 MX180 Shabah 3.0L Alpha 1
    Send midwest mariah:
    Hi Lunaticutah,
    The one he referrers to is the trim limit switch, it prevents the outdrive from going to high and causing damage when under power.
    So how high should the outdrive go to not cause damage. mine abruptly stops at the middle point on my guage, from there, i need to use the trailer button to get it any higher. I thought this was normal, just double checking if you please.
    Old 07-15-2009, 02:49 PM   #23
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    The Alpha I Gen II outdrive on our '94 182 Barchetta behaves the same way.
    But along those lines: Is it safe to operate the engine with the throttle disengaged from the shifter with that button on the axis on the shift/throttle control, while the drive's "parked" in its trailering position, or is that hard on the drive?
    I only ask that because I accidentally did that, yesterday, after replacing the prop in the water. A friend suggested I could damage the drive that way because, tho it's not in gear, there's still power being transferred to the stern drive.
    Jim
    Old 07-15-2009, 03:14 PM   #24
    94z190talari's Avatar
    94z190talari is currently offline
    My Model: Z190 Talari
    My Engine: 4.3LX
    Gallery Images: 12
    Send 94z190talari:
    Do not operate the boat with the engine any higher than the trim button will take it. If you do - only at idle speeds and I wouldn't do that very long.
    The gears are not made to work at those severe angles and will cause damage $$$$.
    You won't be happy with the results.
    I have run mine up higher when going through some stumpy fields on the Brazos river but not for long.
    Old 07-15-2009, 03:18 PM   #25
    My Engine: 4.3LX
    Gallery Images: 12
    Send 94z190talari:
    Like I said in earlier post - use the trailer button to raise it on trailer but don't run it like that. If you trimmed any higher at speed it would handle really squirrely and do a lot of damage.
    The trim button going halfway is normal - and you don't normally need to use all the way up to get top speed and good handling. Only time mine would be that high would be stumpy or shallow areas (going very slow).
    Old 07-15-2009, 04:25 PM   #26
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Jim
    It'll be hard on the U-joints, and could potentially overheat if your drive is raised so that the sea water intake is out of the drink...
    Actually, I believe it stresses the U-joints.
    My Mariah
    Old 08-30-2011, 06:45 PM   #27
    sandon is currently offline
    My Model: Z250
    My Engine: 7.4 Bravo III
    Send sandon:
    what did you clean it with? Just curious I have the same problem
    Old 08-31-2011, 12:50 AM   #28
    My Model: Z250
    Send sandon:
    I have the exact same thing happening. What did you find out?
    Old 07-10-2012, 11:04 PM   #29
    PCap's Avatar
    PCap is currently offline
    My Model: Shabah 302
    My Engine: 8.1 bravo III
    Send PCap:
    HI JGreen
    It sounds repeative as the others have metioned but the trim sender is the place to start as my trim gauage reads full up. My sender is bad and is being replaced now as we speak.
    On my Brovo Three drive its a puck looking unit with a cable lead on side of drive. My trim works but other than looking I had no idea where it was other than feeling where she was based on getting the bow where I wanted her. And yes the transom trim switch works fine on mine reguardless. i need the drive up in my slip so its imperrative to know where the drive is.
    Im no mechanic just going thru this now and pretty handy and I want to be able to help
    Paul
    Old 07-07-2022, 04:25 PM   #30
    CocoJoe's Avatar
    CocoJoe is currently offline
    My Model: 180 Talari
    My Engine: 3.0 Mercruiser LX 135
    Send CocoJoe:
    1995 Mariah Talari 180 /3.0 . I’m having an issue raising the outboard … it won’t raise out of water? I hit the throttle trim up it won’t raise when it’s down. The trim works on water. I was able to jump the solenoid on pump/motor to raise the outboard. Is there something I’m not doing correctly to raise the outboard with the switch??
    throttle lever puzzle deblynlea Original Mariah Talk 4 09-25-2023 12:51 PM
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 339 users
