Trim won’t go up while underway
Old 06-21-2020, 01:11 PM   #1
Shabah z252 is currently offline
My Model: Shabah
My Engine: 5.7 Bravo 3
Send Shabah z252:
Default Trim won’t go up while underway
I have a 97 Shabah z252 with a mercruser 5.7lx and a bravo 3 out drive. The trim up function works while idling and in gear but not under any real load. If I’m crushing even at around 1500 rpms, I can’t trim up. If I slow down to idle speed while in forward gear it goes up. Any and all advice/suggestions would be greatly appreciated. Thanks
  • Old 06-21-2020, 07:40 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Trim won’t go up while underway
    My guess is you have a wonky trim limit switch on your outdrive.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-21-2020, 10:48 PM   #3
    My Model: Shabah
    Send Shabah z252:
    I thought about that being the issue but it won't go up if I hit the trailer button either. Would that also effect the trailer button?
    Old 06-21-2020, 10:56 PM   #4
    My Model: Z280
    No, the trailer button over rides the trim limit switch. Sounds like you have a bad up solenoid.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-21-2020, 11:01 PM   #5
    My Model: Shabah
    Send Shabah z252:
    I changed that over the winter because the trim was only working sometimes. It ended up being the plug. Could it be the pump is not putting out enough to trim up under load? Thanks for your responses.
    On another note, had the porcelain blow out of one of the plugs at W.O.T today. Good times
    Old 06-21-2020, 11:50 PM   #6
    My Model: Z280
    If the pump runs it should have more than enough power to trim out the outdrive. Maybe it is a wiring issue inside the throttle/shifter, only when the throttle is advanced a number of degrees. Try with the engine off, pushing the throttle only button and advance the throttle to various positions while checking the trim operation.
    Haven't heard of a plug failing like that in years.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-21-2020, 11:57 PM   #7
    My Model: Shabah
    Send Shabah z252:
    Thanks, I'll try that. I plan on giving it a tune up this week. I was going to wait until winter but now it will be Wednesday.
    After the plug failed, I noticed some hot water dripping from around the area. Any idea where the water could have come from. I bought the boat last spring and am pretty unfamiliar with the marine engine as of now.
    Any and all advice is appreciated. Thanks
    Old 06-22-2020, 12:04 AM   #8
    My Model: Z280
    Hopefully the hot water dripping is from a poorly sealed drain plug on the exhaust manifold. It wasn't coming from the cylinder or the head gasket.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-22-2020, 12:08 AM   #9
    My Model: Shabah
    Send Shabah z252:
    It seemed to be above the spark plug hole more towards the exhaust manifold. It was always dry before that happened so I hope no major damage was done. I guess I'll find out Wednesday when I lokk at it. Thanks for all your replys, I appreciate it
    Old 06-22-2020, 12:56 PM   #10
    CJ Construction is currently offline
    My Model: Shabah
    My Engine: 5.7L Alpha
    Send CJ Construction:
    (Not trying to hijack) My trim switch only works in the down direction. The trailer button works to raise, so that's what I have to use. Would the above also likely apply to my situation?
    jvar972 likes this.
    bravo three , trim pump
    trim tobqluu Original Mariah Talk 7 10-21-2017 11:50 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Outdrive Trim Sensor & Trim Limit Switch Replacement WetWilly General Maintenance 0 05-26-2009 06:01 AM
    trim dieselwiezil Original Mariah Talk 1 08-01-2008 08:27 PM
    There are 406 users
