trim
Old 08-01-2008, 07:55 PM   #1
dieselwiezil is currently offline
My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
Send dieselwiezil:
Default trim
my trim gauge is starting to act wierd... It has been working great, but now Ill put the boat in the water take off with the gauge working, then after a little bit the gauge pegs up to where it would appear you were running in trailer mode.
I see the anode on the outdrive, is it possible that there could be some corrosion in there?
2000 Mariah 212 Mercruiser 350
2002 F150 Supercrew
1996 F250 Diesel lots of power goodies.
"Out of everything I have, I still prefer riding MARIAH"
  • Old 08-01-2008, 08:27 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Most likely it's your trim sending unit. Yes, it's the cylindrical, plastic housing on the starboard side of the lower unit.
    These are completely non-adjustable or servicable. If it's bad, you'll need a new sending unit, and a trim limit switch (the cylindrical, plastic housing on the port side exactly opposite of the sending unit). It's not cheap. They need to remove the outdrive to run the wires (which is most likely where the water intruded and caused it to act up) up to the bilge area. I just had mine replaced for about $250-$300 if I remember correctly.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    Sensor Warning On Trim? 2 OWNER MARIAH Original Mariah Talk 4 06-10-2008 03:33 AM
    MX19 trim scheme rpeterson Original Mariah Talk 0 06-05-2008 12:14 AM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 301 users
