trim
Old 09-19-2017, 12:38 AM   #1
tobqluu is currently offline
Send tobqluu:
Default trim
Hello everyone, i took my boat out last weekend and the trim/tilt wouldn't lift the stern up. it will goes down but once i tries to raise it up, it just make a clicking noise.
I am thinking its my Trim Solenoid Relay Switch. How do i find out what part to get, i look but there's a p/n on the tilt trim motor.
Tilt motor is a SAE J1171
Stern drive is a Alpha 1 Gen 2
1994 Tarli 4.3 L
Thanks!
  • Old 09-19-2017, 01:36 AM   #2
    Tinman2809 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Yamaha stern
    Send Tinman2809:
    Default Re: trim
    It's easier for the motor to go down then be raised....do you have an external switch on the transom where u can lift it up and down? Try that...my Yamaha has one of works 100% my throttle handle works 75% of the time.. next I would check to see if u have any leaks...see if your arms ( the polished part) are wet
    Old 09-19-2017, 02:00 AM   #3
    Send tobqluu:
    Default Re: trim
    Mine is inboard, it doesn't have an external trim switch,, but I know what you're talking about, cuz my brother Carolina Skiff have one. There aren't any leaks on the arms, that's how I got it to lift up, I took the outer arm bolt out and tie stern drive to my boat.
    Old 09-19-2017, 02:26 AM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: trim
    If one solenoid is clicking, the most likely cause is a bad contact at the 110 Amp fuse on the solenoid bracket. Even though that fuse only runs power to the motor, the same connection provides power to the 20 amp solenoid circuit. That connection and fuse will draw more current in the up direction than in the down direction. Also check the connection of the wire from the ground bolt to the trim motor.
    Another less likely cause is a bad connection in the 20 Amp inline fuse. Remove the fuse and reinstall it into the fuse holder.
    Old 09-19-2017, 02:31 AM   #5
    Send tobqluu:
    Default Re: trim
    Thank you! I will try it out tomorrow.
    Old 10-04-2017, 06:36 AM   #6
    Send tobqluu:
    Default Re: trim
    took all the wires out (2 batteries) reconnected the ground wire (ground was rusted from the engine side) ran two separate grounds to the engine. Replace two new relay switches, everything started up and running!
    Thanks!
    Old 10-09-2017, 01:21 AM   #7
    ROY850 is currently offline
    My Model: 202 Shabah
    My Engine: 4.3L alpha one
    Send ROY850:
    Default Re: trim
    I just replaced my solenoids because I was getting the clicking sound as well. I ordered two new solenoids for up and down , they worked like a champ. I also blew the lines out with brake cleaner and replaced fluid with 10w30 engine oil. What a difference.
    Old 10-21-2017, 11:50 PM   #8
    Default Re: trim
    Read the Trouble Shooter in the General Maintenance Section. Its not a difficult fix.
    Trim Tab Lindy Original Mariah Talk 2 06-11-2012 10:39 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Outdrive Trim Sensor & Trim Limit Switch Replacement WetWilly General Maintenance 0 05-26-2009 06:01 AM
    trim dieselwiezil Original Mariah Talk 1 08-01-2008 08:27 PM
    There are 367 users
