Fuel type
Old 10-04-2017, 04:23 AM   #1
CBZ212 is currently offline
My Model: Z212
My Engine: 5.7 Merc
Send CBZ212:
Default Fuel type
New owner of 92 Z212 with a 5.7 Merc. It's been 21 years since I bought my first Mariah, so I can't remember what octane of fuel to use. I live in Texas and regular is 87 octane. Is it ok to use 87 with 10% ethanol?
  • Old 10-04-2017, 03:17 PM   #2
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    Default Re: Fuel type
    In my opinion, the marine environment is a harsh place for an engine. Give it every advantage and don't use Ethanol. The alcohol will attract moisture (water) into the fuel system. Real gas is a little more expensive but worth it to me. I run 91 octane in my 95 5.7 mercruiser. Not sure it really helps performance but it makes it seem like it goes faster
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Old 10-04-2017, 04:40 PM   #3
    Tinman2809 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Yamaha stern
    Send Tinman2809:
    Some areas your stuck using fuel with ethanol fuel..in NJ I haven't found any area that is ethanol...i personally put 93 into my 4.3 Yamaha usually with a can of seafoam
    Old 10-05-2017, 03:22 AM   #4
    My Model: Z212
    My Engine: 5.7 Merc
    Send CBZ212:
    Thanks!
    I have located a couple of stations locally that have no ethanol fuel. I'll probably use mid-grade or higher.
    Old 10-05-2017, 07:28 PM   #5
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    I think Mercury says 87 Octane (91 RON) without ethanol but if I run the lower grade on my little 3.0 it will diesel (run on when shut off). That tells me the compression is just high enough that depending on ignition advance there's a chances of detonation so I run Premium only. Small price to avoid potential engine damage and some places the only alcohol FREE fuel you can get is Premium anyway. I have to run the same fuel in one of my old cars also.
    Edit: left out the word FREE
    Old 10-06-2017, 03:38 AM   #6
    Bigred89 is currently offline
    My Year: 1991
    My Model: MX19
    My Engine: Merc 4.3l / Alphaone
    Send Bigred89:
    Also, be aware of pumps that have 1 nozzle for all three grades. Tests have shown that there can be up to 5 gallons of 87 octane with 10% ethanol left in the hose and pipes before you actually get the 91 non-ethy. I usually will select the premium and pump about 5 gal into a gas can then start filling my boat. (You could also pump it into your truck.....I have a Duramax diesel so that wouldn’t go over so well for me)
    Old 10-06-2017, 03:57 AM   #7
    Send Scottie1961:
    I think they have an additive for that😊
    Old 10-09-2017, 10:57 PM   #8
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    If I haven't used my boat in a while or first time I use it in the season I always put premium in it. So it cleans out some of the gunk that may still be in the motor. From there on out I just put regular in
    Old 10-10-2017, 01:18 AM   #9
    Levy30 is currently offline
    My Model: 211 Talari
    My Engine: 5.7 Liter Alpha 1
    Send Levy30:
    Any boat old or new should run 100% gasoline. NO ethanol. Marine pump gas is this way for good reason. Worth the extra money per gallon for any boat. Most ethanol free gas is 90 octane. Should be plenty unless you have high HP motor or compression.
    Which Type of Mariah do Ii have ? vw-bussmann Original Mariah Talk 38 02-21-2018 09:07 PM
    type of oil for 7.4 ??? gman Original Mariah Talk 0 06-06-2011 09:53 PM
    Type of tow vehicle? m&mmariah Trailering and Tow Vehicles 0 07-27-2010 04:28 AM
    Exact engine type help mjhinno Mercury MerCruiser 2 05-24-2010 05:29 PM
    type Numbers Shabah203 Original Mariah Talk 3 08-16-2009 02:41 PM
    There are 357 users
