Losing All Electrical Power to Dash
Old 06-24-2014, 01:47 PM   #1
patrickrk is currently offline
My Model: MX20
My Engine: 5.0 LX, Alpha I
Send patrickrk:
Default Losing All Electrical Power to Dash
I have a 93 MX20. It was recently in the shop because I had absolutely no power to the dash switches, gauges, or ignition. They found a lose cannon plug to be the culprit. Was just going through the boat this morning, all accessories, gauges and ignition worked fine until I hit the dock light switch. It worked the first time through, the second time I lost all power to the dash. After 1-2 minutes the power seemed to come back slowly, really dim lights on accessory switches. After 1-2 minutes longer, everything was back to seemingly full power and ignition worked again. Before taking it to the shop, I believe it was the dock light switch that was killing the power. Does anyone know what might be going on here? I am afraid to touch that switch!
  • Old 06-24-2014, 06:55 PM   #2
    Default Re: Losing All Electrical Power to Dash
    Sounds like you have a bit of electrical shorting going on. Check the wiring at the dock light switch, the fuse panel and at the lights just to ensure a bare wire isn't causing the problem.
    lost electrical power after main fuse panel bfinn Original Mariah Talk 0 06-15-2011 04:36 AM
    dash fading or white residue on dash 2009 sx20 wakenbake Sea Fox - Mariah Talk 1 02-24-2011 06:37 PM
    losing fuel pressure D_Man Mercury MerCruiser 0 07-17-2010 07:39 PM
    losing fuel pressure D_Man Original Mariah Talk 0 07-17-2010 05:30 PM
    There are 269 users
