Electrical problem..main electrical
General Maintenance
Old 08-02-2010, 05:42 PM   #1
mlnevill is currently offline
My Year: 2006
My Model: SX19
My Engine: 4.9 Merc
Send mlnevill:
Question Electrical problem..main electrical
All of my switches on the dash are dead, each switch has it's own reset button. I assume that there is a master breaker or fuse but can not locate it on a 2006 SX 19. Any one know where this might be located??
  • Old 08-03-2010, 02:27 PM   #2
    recelect is currently offline
    Send recelect:
    Default Re: Electrical problem..main electrical
    there should be a big red resetable Circuit breaker located on the engine, but that also should be controlling ignition and gauges. If it is blown, I would bet you have a bigger electrical issue. does anything electrical up front work?
    I am not too familiar with your setup, but in general, main breakers and fuses are and should be located as close to the battery as possible. There is also a chance that there is a fusable link coming off the starter to the switches, or a breaker mounted somewhere close to the battery.
    Have you had any work done to your boat recently? if so what? Maybe something didn't get reconnected?
    Intermittent Electrical Problem jwpilger General Maintenance 13 08-13-2009 02:44 AM
    Electrical Problem with Gauges Douglas Alderman Original Mariah Talk 4 07-15-2009 05:36 PM
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    Electrical Z210Shabah Original Mariah Talk 3 04-05-2009 11:40 PM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    There are 315 users
