Bravo three ticking noise
Old 06-10-2014, 02:59 PM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Bravo three ticking noise
Boat is in the shop again. Just had the prop seal replaced, got it home and hooked up the earmuffs, fired it up and heard a slight whirring noise and a ticking (a very light knock) coming from the upper gear unit or gimbal area. Wasn't doing this before the seals were replaced and had recently put a new gimbal bearing in. U joints were in good shape and it makes the noise regardless if it's in gear and doesn't get worse or better if the steering is turned or not. Any ideas? It's been sitting in line at the shop for three weeks and I keep getting the run around of when they can look at it
  • Old 06-11-2014, 06:39 PM   #2
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Default Re: Bravo three ticking noise
    Do you know if they changed the gear oil when they replaced the prop seal? If they didn't I would check the gear oil level, then drain the oil and check for any contamination(ie. metal). If no problem is found there, I would probably pull the outdrive and check for any slack in the upper drive shaft that passes thru the gimble bearing. While that is off you can also again check the u joints, gimble bearing, gimble bearing housing, shaft alignment, etc. But I would start with the gear oil first.
    Hope this helps
    Dan
    1995 Z272 Barchetta
    bearing noise? num12 Mercury MerCruiser 11 05-08-2014 02:50 AM
    LOUD Tapping Noise mmckenzie6 Boating 101 4 04-19-2014 06:50 PM
    Engine noise Juno Original Mariah Talk 1 08-17-2012 02:44 AM
    alpha one noise mwads275 Introductions 5 09-24-2010 12:53 PM
    Beeping Noise??? llcelebrity Original Mariah Talk 3 08-13-2009 04:34 AM
    There are 276 users
