losing fuel pressure
Old 07-17-2010, 07:39 PM   #1
D_Man is currently offline
My Model: Z242 Shabah
My Engine: 7.4 Bravo 3
Gallery Images: 1
Send D_Man:
Default losing fuel pressure
My '98 Shabah with 7.4 Bravo 3 won't run over 2000 rpm under load. Put fuel gauge on her and shows a steady 38 psi with key on and at idle. Motor will rev to high rpm by itself, but fuel pressure guage will gyrate quite a bit. But when I take it out on water and under load it holds fuel pressure, until I reach 2000 rpm where the fuel pressure goes to almost 0. Throttle back and pressure returns and will idle perfect.
I replaced fuel filter/water seperator, distributor cap and rotor, and put the appropriate amount of sea foam in fuel. I did read on web blogs about similar problems and a filter screen at the fuel regulator getting clogged. My fuel pump and regulator are located in a small plastic box on the lower side of the block. Can't get the cover off this box as its up against the fiberglass hull where mtr mnts are fastened. Does anyone know how or if this cover can be removed??? Thanks for any help.
    New Owner-Backfiring and Oil Pressure bwolf123 Mercury MerCruiser 4 07-17-2012 02:24 PM
    losing fuel pressure D_Man Original Mariah Talk 0 07-17-2010 05:30 PM
    Oil Pressure my97camaro General Maintenance 0 06-15-2010 03:11 PM
    Oil pressure too high??? DGR-Z246-98 Original Mariah Talk 6 11-02-2009 03:34 PM
    Alarm Sounding, but pressure/temperature look fine? aggressivebuggy Sea Fox - Mariah Talk 5 06-29-2009 04:59 AM
    There are 349 users
