Exhaust Riser
Old 12-30-2021, 10:18 AM   #1
markyta is currently offline
My Model: Diablo 18
My Engine: 4.3 Merc
Send markyta:
Thumbs up Exhaust Riser
I have a 2001 Mariah Diablo 180 with a Mercruiser 4.3 V6. It has an Alpha 1/Gen 2 outdrive. The exhaust risers are 1 piece. When I do research for new ones, they all show the 2 piece versions. Does anyone have any info on the difference or compatibility of the two?
Thank you.
  • Old 12-31-2021, 02:03 AM   #2
    Tlolesen's Avatar
    Tlolesen is currently offline
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Default Re: Exhaust Riser
    I had a 2001 Shabah 182 with the same motor and one piece risers a couple years ago I had water in the oil and turned out the water passage in the port side was leaking, the shop that changed it out put in the 2 piece one's I was told that mercury only did the one piece for a short time and they are known to fail so they recommend to do the 2 piece, I had them do the starboard side the next year just to be proactive.
    Old 01-01-2022, 11:14 PM   #3
    My Model: Diablo 18
    My Engine: 4.3 Merc
    Send markyta:
    Thank you for the help. Would you possibly know the part numbers you used for the replacement?
    Old 01-02-2022, 12:13 AM   #4
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    No I don't
    The shop that did the install bought everything
    Old 01-02-2022, 04:10 PM   #5
    There is a good thread here on this site regarding replacing the 'batwing' manifolds/risers: 4.3LX Owners, Listen Up
    Help please?! I can't find my exhaust riser elbow gasket Koolaid Mercury MerCruiser 2 03-25-2021 02:03 PM
    5.7 Exhaust Manifolds jarwiebe General Maintenance 4 09-22-2013 07:54 PM
    01 z252 merc 7.4 riser size super10lbz Original Mariah Talk 0 04-13-2010 05:25 PM
    3.0 Mercruiser Riser to Manifold Leak 1999Mariah Original Mariah Talk 2 06-12-2009 01:14 PM
    Exhaust TALLRAM Original Mariah Talk 2 12-17-2008 05:08 PM
    There are 284 users
