5.7 Exhaust Manifolds
General Maintenance
Old 09-22-2013, 01:49 AM   #1
jarwiebe's Avatar
jarwiebe is currently offline
My Model: Z210 Shabah
My Engine: 5.7 LX Alpha I
Gallery Images: 2
Send jarwiebe:
Default 5.7 Exhaust Manifolds
I went to winterize my 5.7 today and was unable to remove the drain plugs from the bottom of the exhaust manifolds. This is the first time I am doing my own winterizing and am not sure if my marina (they went out of business this past spring) every pulled the plugs. Does pulling the hose off the bottom of the bottom of manifold drain it and the riser or do I need to get those plugs out to drain properly? I would prefer to drain versus sucking up antifreeze via the muffs.
Cheers
Jake
1996 Z210 Shabah
Mercruiser 5.7LX
Alpha One Drive
80 Lb. SX Smart Tabs
  • Old 09-22-2013, 03:49 AM   #2
    Default Re: 5.7 Exhaust Manifolds
    I wouldn't be comfortable not getting the plugs out.
    Sucks for sure , but if it was me .......... I'd pull the manifolds and get the plugs removed. Drill em out if you got too.
    I have seen guys fill the engine with RV antifreeze via open thermostat housing ,reinstall housing , and start engine momentarily............. but I wouldn't risk it.
    To many things can go wrong.
    Pull the manifolds , drill em , and use a easy out to remove. Install new plugs.
    You'll sleep a lot better!
    Old 09-22-2013, 06:26 PM   #3
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    If you decide to take them out, try to heat them up with a torch first. I've had good luck heating and then pouring water on the plug. Seems to break the set loose. I hate having to use a drill. :banghead:
    Old 09-22-2013, 06:54 PM   #4
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Has any one of you ever used "CRC Freeze Off Super Penetrant " just found this on youtube and looks like it might work to loosen the drains.
    CRC Freeze Off Super Penetrant - YouTube
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 09-22-2013, 07:54 PM   #5
    husker_fan's Avatar
    Send husker_fan:
    I have. Its worth a shot. Same principle as the heat and cool with torch and water. It works sometimes and some not. I'd try it before I pulled them off.
    New 7.4 MPI manifolds Motoxxx43 Mercury MerCruiser 3 04-22-2013 07:01 PM
    Water issues/exhaust manifolds drdruz11 Original Mariah Talk 0 05-03-2011 06:32 PM
    Batwing manifolds bones774 Original Mariah Talk 9 06-22-2009 03:52 PM
    Newer Exhaust Manifolds cracking? aggressivebuggy Mercury MerCruiser 3 05-22-2009 07:07 PM
    Replacing Exhaust Manifolds? 300sflyer Mercury MerCruiser 6 01-22-2009 07:05 PM
    There are 253 users
