Faria Tach Replacement
General Maintenance
Old 11-08-2011, 02:01 AM   #1
Yellow Jacket is currently offline
My Year: 2006
My Model: SX19
My Engine: 4.3L MerCruiser
Send Yellow Jacket:
Default Faria Tach Replacement
The Faria tach on my 2006 SX-19, 4.3L V6, suddenly went from normal operation/indication this summer to reading approximately twice as high as it should. I will check connections for corrosion, but what suggestions do any of you have for troubleshooting?
Also, if it comes to relying on Faria's lifetime warranty, do any of you have experience in working with Faria to get a replacement tach?
Yellow Jacket
  • Old 11-08-2011, 02:54 PM   #2
    Default Re: Faria Tach Replacement
    Faria has been good at honouring their warranty if there is something defective within the tach. While you are checking the connections for corrosion, give the small dial on the back of the tach a spin a few times then re-set it at "6 cyl".
    faria , tacho
    Dead Tach Z222 Original Mariah Talk 3 08-02-2011 05:38 PM
    2000 Z 272 Tach garyg Projects 5 12-16-2009 07:14 PM
    Tach Question ewcjoro Original Mariah Talk 1 08-11-2008 01:43 PM
    Inconsistent Tach MAJIC Original Mariah Talk 4 07-03-2008 02:29 PM
    Bad Tach/Compass WolfProperties Original Mariah Talk 6 05-05-2008 06:43 PM
    There are 330 users
