Tach Question
Old 08-10-2008, 09:18 PM   #1
ewcjoro's Avatar
ewcjoro is currently offline
My Model: Z202 Shabah
My Engine: 5.7L Alpha I
Send ewcjoro:
Question Tach Question
All -
I am having issues with my tach and I had a few quick questions...
(I have tried the "switch" trick moving the engine size selector to fix the connection problem with no luck.)
1. What RPM's does the gauge sit at when the engine is off? (Mine sits at 1k RPM)
2. Is there a way to test the signal from the engine to ensure that the wiring is ok?
3. Any other things to try before removing/repairing/replacing?
Thanks in advance!
More good times...
1999 Shabah Z202
5.7L Alpha 1
  • Old 08-11-2008, 01:43 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    I have the older Faria gauges (white on black) but my tach needle sits below zero with the key off, and reads zero with the key on.
    Not sure what else you can check, but Faria offerd a limited lifetime replacement on all their gauges for a nominal fee ($30 for a tach). You just have to remove and send them the old one.
    You can get contact info here: http://www.faria-instruments.com/
    My Mariah
    Having problems with Tach & Speedo rickt48 Original Mariah Talk 9 06-21-2011 02:52 PM
    Inconsistent Tach MAJIC Original Mariah Talk 4 07-03-2008 02:29 PM
    A/C Question WolfProperties Original Mariah Talk 6 05-07-2008 12:56 PM
    Bad Tach/Compass WolfProperties Original Mariah Talk 6 05-05-2008 06:43 PM
    Odd Tach Problem sledge437 Original Mariah Talk 3 04-29-2008 04:49 AM
    There are 233 users
