5.7 inboard issues
Boating 101
Old 04-29-2010, 01:48 PM   #1
chriskeller82 is currently offline
My Model: z2000
My Engine: 5.7 L Alpha 1
Send chriskeller82:
Default 5.7 inboard issues
I have a 92 Z2000 with the 5.7 inboard and I took it out for the first time this spring and the engine wants to cut out when i open the throttle full....it is not due to over reving. It feels like the engine is starting to flood itself out. if i feather the throttle on the way to the top end it gets there but if i open it up it cuts out. I was thinking that it might be the gas that has been sitting in the boat all winter as i live in ND. Any help is appreciated
C
  • Old 04-29-2010, 05:23 PM   #2
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    Default Re: 5.7 inboard issues
    Sounds like a partially plugged gas filter. Try changing them and see if it then runs OK. If it has a carb then check the filter in the body where the fuel line attaches. Let us know if this helps.
    IowaWing
    Steve
    Old 04-29-2010, 05:34 PM   #3
    Hi chriskeller82, in addition to the fuel filter, I would check the choke and accelerator pump if you have the carbed model 5.7L.
    Old 04-29-2010, 05:49 PM   #4
    Send IowaWing:
    If it only cuts out during acceleration and not at Wide Open Throttle, then WetWilly is right with his diagnosis. If it cuts out at WOT too then the filter is the problem.
    IowaWing
    Steve
    Old 07-24-2010, 10:09 PM   #5
    SuperdaveTX's Avatar
    SuperdaveTX is currently offline
    My Model: Shabah 202
    My Engine: 5.7 Alpha One
    Gallery Images: 8
    Send SuperdaveTX:
    You may have fixed this already, but I will chime in as this happened to me when I bought mine.
    Same exact thing.. ran fine, but just after plane, it would flood kinda..
    Well, for mine, the ignition cable is not one long cable. My cable goes from the key to just behind the stereo. Here a connector is used join the second length of cable to extend it back to the engine. After checking almost everything out twice, I found that the male connector was just touching the female connector. I plugged it in all the way...and no problems since!
    Shifter issues RPOLS3 Original Mariah Talk 6 09-03-2011 05:11 AM
    fuel issues murphysocc Mercury MerCruiser 9 09-14-2009 09:59 PM
    Prop Issues donb. Prop Talk 5 08-12-2009 09:23 PM
    Prop issues 95Z212 Prop Talk 9 07-28-2008 03:55 PM
    Help with starter issues MariahShabah3.0 Original Mariah Talk 10 09-10-2007 06:04 PM
    There are 310 users
