How long can I run my stereo without draining the battery?
Boating 101
Old 07-11-2010, 10:37 PM   #1
Wakeboarder5272 is currently offline
My Year: 2004
My Model: SX18
My Engine: 3.0 Alpha 1
Send Wakeboarder5272:
Default How long can I run my stereo without draining the battery?
Hi everybody,
So everytime that I'm out out with the family or my crew and we're anchored, I always get nervous about running my stereo because I don't want to kill the battery and not be able to get the boat started to get back to the dock. Does anybody know how long I can run my head unit with no worries about killing the battery (I have a Sony marine HU and 4 marine kicker 6 1/2's if that matters)? It would definitely be nice to have some tunes to listen too while we're swimming and chillin.
Rick
  • Old 07-12-2010, 10:06 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: How long can I run my stereo without draining the battery?
    Tough question because it depends on a ton of factors. How new is your battery? What is the CCA of the battery? Is it deep cycle? I assume it's single not dual battery set-up?
    Assuming a standard marine starting/deep cycle battery with a stereo and no amp, in good condition... I think you're good for at least 3 or 4 hours, probably even 6 or 8. I have 2 batteries in "okay" condition with 2 amps drawing a lot of power and I can run at least 3 or 4 hours without worry.
    Hope this helps. Just bring jumper cables and a friends boat, run it all day and see what happens. I'm betting you'll be surprised how little a head unit with 4 speakers pull from the battery. But it's a good thing you're asking and concerned about it - being stranded in the middle of the lake/river is never fun!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 07-12-2010, 10:50 PM   #3
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    I can run mine for about 4 hours but i start my boat every hour just to give the battery a little charge. You should also have a second battery just incase.
    Quietly Making Noise
    Old 07-12-2010, 11:21 PM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    I've run mine (Plain old Sony radio of some kind, two speakers) for a couple hours or so to no ill effect. We have a brand new battery.
    If I was going to be running the stereo for hours at a time regularly, I'd definitely have a two-battery setup: A starting battery, a "house" battery and either an ACR or Echo Charge device.
    Jim
    Old 07-13-2010, 02:24 AM   #5
    My Year: 2004
    My Model: SX18
    Yes it's a standard deep cycle single battery set up with no external amps (yet). I appreciate the advice. I don't think I'll need to run it for anymore then an hour or 2 at a time I should be good to go.
    Old 07-13-2010, 12:24 PM   #6
    SEMIJim's Avatar
    Send SEMIJim:
    If it's a new(-ish) battery that's in good condition and it's fairly well topped-off, charge-wise, with a plain ol' stereo (no amps or subs), you should be good for a couple hours or so.
    If you're worried about it, buy a jump box and throw that aboard. Just make sure to follow the manufacturer's recommendations on keeping the jump box up to snuff.
    Jim
    Old 07-20-2010, 12:41 AM   #7
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Yes. Simple stereos don't chew up too much. I ran repeatedly for several hours at a time last summer and my battery was 6 years old! Wouldn't hold a charge this winter though. I didn't owe me anything at that point.
    If you are really worried and you don't have a dual battery setup, just do as I do and carry a portable battery booster. Always good to be prepared.
    My Mariah
    Old 07-24-2010, 09:46 PM   #8
    SuperdaveTX's Avatar
    SuperdaveTX is currently offline
    My Model: Shabah 202
    My Engine: 5.7 Alpha One
    Gallery Images: 8
    Send SuperdaveTX:
    Yeah.. Always start engine after an hour or so is a good idea.
    Something else to consider. If you do not have an onboard charger, look into getting one. You just plug your boat in when you get home and it is fully charged when you go out next time and it is easy. Also, this keeps your battery in good shape. My optima lived for over 6 years doing this.
    Old 07-25-2010, 03:18 AM   #9
    garyg's Avatar
    garyg is currently offline
    My Model: Z272 Shabah Open bow
    My Engine: 7.4 LMPI Bravo III
    Send garyg:
    Wakeboarder I have TWO Batteries and switch so you can a back-up for like leaving things on.I switch batteries every time we go out so both battery is used and ready to go. I have had two batteries on my last three boats.There have been many times I was glad to have had them. Thats my 2 cents worth. Gary G
    draining water from block m&mmariah Boating 101 2 06-18-2010 03:00 PM
    Bilge not draining jhaag41 Original Mariah Talk 1 05-04-2010 04:02 AM
    Long lake Rider mark shipley Introductions 1 02-20-2009 11:25 AM
    Been gone too long!!! moondance100 Chit Chat/Off-Topic 9 01-30-2008 05:31 AM
    There are 256 users
