Pictures of some of my projects/modifications
Projects
Old 06-15-2009, 11:52 PM   #1
Talari240ZinAZ's Avatar
Talari240ZinAZ is currently offline
My Model: 1995 Z240 Talari, Mercruiser 7.4L Bravo I Polo/Ivory
Gallery Images: 26
Send Talari240ZinAZ:
Default Pictures of some of my projects/modifications
I finally got around to uploading pictures of some of modification projects that I've undertook since I boat my boat. I went ahead and placed them as sets in my gallery along with a short description of the project.
Installed thru-hull exhaust/Corsa diverters
Automatic Fire Extinguisher and Vapor Detector
Second battery/battery combiner and onboard charger
Replaced original mechanical hatch lifters with hydraulic system
Bennett Sport Trim Tabs
Flush-mounted VHF radio, Stainless Docking Lights, Stainless Rub Rail, mid-ship cleats, replaced fixed-height seat pedestals
If anyone has any questions or wants additional detail, just let me know.
Scott Wenzel
Tempe, Arizona
  • Old 06-16-2009, 05:48 PM   #2
    WetWilly's Avatar
    WetWilly is currently offline
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Default Re: Pictures of some of my projects/modifications
    Hi Talari240ZinAZ, nice job on those cutouts and tabs!
    I assume you've had the cutouts on for quite some time, have you ever experienced any problems with slowing down quickly and getting water in the tips?
    I have been worried about the water because the way our Talari sits, with the tips in the same location as yours, they would only be a couple of inches above the water line at rest and any quick slowdown would jam water right into them. I would have thought it would be the same issue for you, guess those flapper valves and the 3" extensions really do solve this problem.
    I believe our Z240 would use the same kit as yours so I was wondering if you happen to remember the Kit or model number of your cutout system.
    WetWilly
    Old 06-16-2009, 09:27 PM   #3
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    I just ordered from Corsa. Since we share the same boat I can provide all the info for you.
    Brent
    Brent
    1995 Talari Z240
    7.4L Merc, Bravo III Outdrive
    Corsa Performance Captains Call Exhaust
    Samson Sports Tower
    Old 06-16-2009, 09:50 PM   #4
    Gallery Images: 26
    I've never had a problem with backwash getting back up through the exhaust. I was down in Rocky Point on the Sea of Cortez back in the late 90's and took some pretty good breakers square against the back of the boat when the engine wasn't running. Didn't hurt a thing although I just about had a heart attack looking at my Z240 leaning to the side up on the beach. Surely have to thank God there were plenty of people to help push the boat back off the beach when the tide came back in.
    Corsa part numbers in the kit were:
    Make sure you have both your engine serial # and hull # to provide them with your order.
    13147MB11 - Pair Merc 454/502 Elec Valve with offset.
    11000MBI1 - Pair 4" Angle Cut Tips for Mariah Boats.
    1700 - Pair Std. Hoses 5" and Clamp Kit (8).
    Scott Wenzel
    Tempe, Arizona
    Old 06-17-2009, 05:15 AM   #5
    WetWilly's Avatar
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Hi Talari240ZinAZ, many thanks for the part numbers and the ordering tip and bdbyrnes, anything you can add would be appreciated as well
    OMG!! Your Talari looks a whole lot bigger when it's beached!!!
    WetWilly
    Old 06-26-2009, 10:06 PM   #6
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    The Corsa tips have an anti surge valve to eliminate such a problem, and valves come with a lifetime warranty. I don't know if that covers engine damage due to failure, but my guess is it's a non-issue.
    My Mariah
    My Shabah is using what the hybrids are saving!
    Old 07-14-2009, 09:35 AM   #7
    WetWilly's Avatar
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Brent
    Hi Brent,
    Could I bother you for the the info and part numbers on your Corsa exhaust... are they similar to Talari240ZinAZ system?
    WetWilly
    Old 07-14-2009, 02:52 PM   #8
    bdbyrnes's Avatar
    Gallery Images: 41
    Send bdbyrnes:
    Not sure the part numbers; I called Jim and he took care of everything...
    Just tell him we have the same boat and you're all set.
    Brent
    Jim Browning Jr.
    Auto Sales Channel Manager
    CORSA Performance Exhausts/GIL Marine
    A TMG Performance Products Company
    800.486.0999 ext 112
    440.891.1868 fax
    www.corsaperformance.com <http://www.corsaperformance.com>
    Brent
    1995 Talari Z240
    Samson Sports Tower
    Old 07-19-2009, 01:59 PM   #9
    WetWilly's Avatar
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Thanks a bunch Brent!
    Travel Pictures - Gallery MariahMan Trips, Travels, and Meet Ups 0 07-13-2008 03:59 AM
    Tons of Mariah Z302 & Z300 Pictures Boatcrazy Original Mariah Talk 1 09-22-2007 03:49 AM
    Total Members: 18,994
    Total Threads: 13,326
    There are 342 users
