Helm/Dash reinforcement
Projects
Old 07-09-2009, 02:12 PM   #1
Talari240ZinAZ's Avatar
Talari240ZinAZ is currently offline
My Model: 1995 Z240 Talari, Mercruiser 7.4L Bravo I Polo/Ivory
Gallery Images: 26
Send Talari240ZinAZ:
Default Helm/Dash reinforcement
Ever since I bought my boat new, I've always been annoyed by the flex in the helm whenever you bear down on the steering wheel. Earlier this season, I decided to do something about it when I was tightening the bolts on the rack where it meets the pinion. I saw that the fiberglass/plywood that the steering column bolt to had developed a crack on the lower side. If you push straight down on the steering wheel, the entire dash flexes with it. Upon removing the steering column completely, I could see why. In manufacturing, they bored a 3 1/2inch hole for the steering column through the face of the helm and another through the top for the compass which compromised the entire structure (see attached pic).
After stufyingI decided a back-plate would definitely solve the problem but when I proceeded to try and make a drawing of what I was thinking of, I soon realized a better approach would be to make a pattern out of hardboard. It worked great, I could slide it in place to check measurements and angles. I used a hot glue gun to join the pieces and making tweaks was easy.
Fortunately, I have a buddy who's got access to a metal shop. Talked to him last evening and he told me they cut some of the pieces out yesterday on their plasma cutter. They're building it out of 1/4" stainless plate. Wow, even though I patterned it with 1/4" hardboard, I figured they'ld use a thinner gauge when they build it. Well, it'll have two purposes, one to reinforce the helm and the other as a heck of an anchor.
Anyways, take a look at some of the picks, I'll post updates as things progress
Scott Wenzel
Tempe, Arizona
  • Old 07-14-2009, 11:38 PM   #2
    Gallery Images: 26
    Default Re: Helm/Dash reinforcement
    Buddy sent me a pic of the progress on my helm reinforcement plate. All tacked together. I may take a run over to check it out tomorrow!
    Scott Wenzel
    Tempe, Arizona
    Old 07-15-2009, 02:18 AM   #3
    otisroy's Avatar
    otisroy is currently offline
    My Model: 182 Shabah
    My Engine: 4.3L Alpha One
    Send otisroy:
    Looks great! You might need an 8 year old to sit on the other side of the boat to keep trimmed. That looks stout.
    Old 07-15-2009, 04:59 AM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Don't mean to be a wet blanket, esp. this late in your project, but what grade of stainless? Not all stainless is equally non-magnetic. It has to be an austenitic stainless--at least 316. And even then: Any cold-working of it will reduce it's non-magnetic properties significantly. I only mention this because of your compass.
    IMO, you'd be much better-off with aircraft-grade aluminum. It would be much lighter, completely non-magnetic, and I would think certainly strong enough for your application.
    Jim
    Old 07-15-2009, 02:02 PM   #5
    Gallery Images: 26
    Discussed the stainless issue with my buddy. Non-issue for me, I carry a GPS in my boat bag. To be honest the existing Richie compass has always been off by 8-10 degrees anyways. Probably due to the steel hardware I found the steering assembly bolted to the helm with. We'll see how it affects the compass but I'm not concerned with it. Appreciate the feedback though!
    Scott Wenzel
    Tempe, Arizona
    Old 07-15-2009, 02:25 PM   #6
    SEMIJim's Avatar
    Send SEMIJim:
    Yeah, I guess I was just being pedantic . We have a little Richie compass on the right of the helm of our Barchetta and, TBH, it seems to be relatively worthless. On our lake there's usually so much chop/waves that the little thing bounces around like a ping-pong ball . I've yet to check it for accuracy, but, yeah, unless Mariah swung the boat to calibrate it (which seems unlikely--it's a painstaking process): With all that other steel close-by, it's probably way off.
    Jim
    Old 07-15-2009, 04:25 PM   #7
    Gallery Images: 26
    Also, the compass is flanked by several switch panels which sit within inches of the compass, that can't help.
    Scott Wenzel
    Tempe, Arizona
    Old 07-15-2009, 06:44 PM   #8
    Gallery Images: 26
    Just reading some installation documentation from Richie and the compensators will handle 20 degrees in deviation (see attached). They also provide instructions for adjusting compensation. We'll have to see what effect the plate has on the compass first.
    Scott Wenzel
    Tempe, Arizona
    Wanted: I need dash switches 94Z212 Mariah Parts For Sale & Wanted 2 10-06-2009 07:30 PM
    Dash ice box lid Mach Man Original Mariah Talk 8 01-07-2009 04:12 AM
    Clarion Remote Control @ helm il_Mio Sea Fox - Mariah Talk 8 08-03-2008 12:45 PM
    Mariah Dash Reinforcement (Pre-97) Rick Projects 2 04-26-2008 10:38 PM
    There are 304 users
