Engine swap question
Sea Fox - Mariah Talk
Old 07-10-2014, 09:38 PM   #1
Lex81 is currently offline
Send Lex81:
Default Engine swap question
Hi Guys,
In my sx20/22 i run a mercury 5.0mpi 260hp engine on a bravo 1.
Say i would have this engine swapped with a 320hp 6.2mpi. Would that increase in HP destroy my boat?! In the boat catalogue it says maximum hp for that type of boat is 260... But why? The bravo1 can handle more.. Who can comment this?.
The engine sizes do not differ that much so i believe it would fit...
What do you guys think?
Regards,
Lex
  • Old 07-10-2014, 09:52 PM   #2
    Default Re: Engine swap question
    The Bravo 1 might be able to handle it but the transom and hull may not be able to.
    Lucky14 likes this.
    Old 07-10-2014, 10:10 PM   #3
    Send Lex81:
    Basicly: don't take the risk situation? Or is it a "small chance" something will give or a matter of time?
    Thanks Mikeyt, you kind a have a good responds and answer to everything
    Old 07-11-2014, 12:03 AM   #4
    Not quite. I know enough not to answer a question when i dont have a clue what the answer is to it.
    I'm suggesting that the boats have horsepower limits because the hull structure or design has a limit on the stress it can handle. If it says 260hp i dont think i would want to push it much beyond that limit. I did once see a guy strap a 150hp Evinrude onto the back of a 14' Grew runabout and then watch it destroy the transom after a couple of hi-speed maneuvers on the water.
    Old 07-15-2014, 10:28 PM   #5
    Lucky14's Avatar
    Lucky14 is currently offline
    My Year: 2004
    My Model: SX19
    My Engine: 5.0L Bravo I
    Send Lucky14:
    Agreed. If it was a truck or car... go for it, you could always weld in brackets, beef the frame and suspension up. But with a boat you have well whatever the structure is under the floor. In the case of Mariah- thats structure foam core stringers and no rot hull. They may have reinforced 6.2 boats up more for the torque and HP and most importantly weight.
    Old 07-16-2014, 12:55 AM   #6
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    When the engine starts spinning instead of the prop you'll know you've gone too far.
    Old 07-18-2014, 09:35 AM   #7
    Send Lex81:
    ok, clear All I needed to hear! I'll stick with the 5.0o mpi! Got a new prop and that absolutely works fine so no more need for extra horses!
    7.4 Engine Swap usafdaytonan Mercury MerCruiser 20 09-24-2013 02:16 AM
    engine swap tommyd Mercury MerCruiser 7 06-30-2013 01:40 PM
    Thinking of Motor Swap? 95Z212 Original Mariah Talk 3 09-30-2012 06:32 PM
    Another motor swap question Weezer Original Mariah Talk 5 09-04-2012 02:46 AM
    305 to 350 swap question howar2539a Mercury MerCruiser 0 06-07-2010 03:48 PM
    There are 245 users
