Manifold Gasket Replacement
Sea Fox - Mariah Talk
Old 08-02-2014, 11:28 PM   #1
jayhawkboater is currently offline
My Year: 2009
My Model: R20
My Engine: 5.0
Send jayhawkboater:
Default Manifold Gasket Replacement
I am getting ready to replace both exhaust manifold gaskets on my 5.0 liter Mercruiser. I am not planning on removing the risers to do the replacement. Are there any secrets or tricks I should know about before I tackle this project?
I saw something on You Tube about making sure I drain the water from something before I unbolt the manifold or water could get inside the engine. Can someone tell me what I need to drain water out of, if anything?
  • Old 08-04-2014, 01:55 AM   #2
    Default Re: Manifold Gasket Replacement
    Drain engine via the blue twist plug for the cooling system(not sure where on that year) , should be fairly easy to spot. Might want to pull hose from front of manifolds just to be safe.
    Easy job , I suggest using a lube of sorts on the rubber boots that go to the Y pipe when reinstalling manifold.
    Old 10-10-2014, 05:35 PM   #3
    Skippern is currently offline
    My Year: 2007
    My Model: SC23
    My Engine: 5.0 MPI Bravo One
    Send Skippern:
    In the bottom front of the engine you have a blue plastic screw, open it and the engine will drain, you should also open the one on the thermostat hosing to get air into the system.
    Why do you have to change the gaskets?
    Wanted: volvo penta carb gasket set andybailey Mariah Parts For Sale & Wanted 9 07-19-2013 10:53 PM
    Exhaust Manifold Replace ColoradoDiablo Mercury MerCruiser 2 01-13-2012 07:20 PM
    Manifold replacement Vilanova Mercury MerCruiser 0 06-10-2011 05:33 PM
    1999 merc 3.0l blown head gasket silver04roush Mercury MerCruiser 5 08-22-2010 05:12 PM
    Windshield screw cover gasket shoot001 Original Mariah Talk 2 02-17-2009 11:55 AM
    There are 378 users
