Gauge Problems-SX18
Sea Fox - Mariah Talk
Old 01-17-2009, 08:24 AM   #1
Vilanova is currently offline
My Year: 2006
My Model: SX18 Bowrider
My Engine: 3L Mercruiser 135hp
Send Vilanova:
Default Gauge Problems-SX18
I have an SX18 coming up 3 yearsold and 110 hours. Some of my Faria gauges have never worked properly from new. The speedo which the dealer told me was bunged up and my own responsibility (the boat having been on the water for 3 days!), Iv'e given up with that altogether. The rev counter now sticks and shows higher revs until I bang it and it drops back to the correct reading. The oil gauge and hour guage steam up and the hour counter is now sticking! I meticulously clean the boat after every outing so the guages are in good condition. I was told they are good guages but I wouldn't have Faria again.
  • Old 01-17-2009, 11:10 PM   #2
    hmmmm...dont hear many complaints about Faria gauges. With the speedo make sure the small vent on the front of the outdrive is clear. It doesnt take much to bung it up and the speedo stops working. You could also try disconnecting the tubing at the back of the speedo and blowing compressed air thru the line in the event something is plugging it. You might also want to check the length of the line to ensure it is not pinched somewhere.
    As for the tach, check the back of the tach to ensure that it is set for 6 cyl (assuming you have the 4.3L). Sometimes spinning the dial around 3-4 times and then resetting it will clean up the problems you mention.
    I'm not sure about the oil gauge or hour meter fogging but check the electrical connection to the hour meter to ensure that its clean.
    Old 01-18-2009, 05:34 AM   #3
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Hi Vilanova, I concur with Mikey, I have no issues with my Fariah gauges what-so-ever. Doing as Mike suggested with the speedo would be my first job.
    Even sending them back to Fariah (as a last resort) as they carry a lifetime warranty, especially the gauges that are fogging.
    Good luck and let us know how you get on.
    Tony
    Perth, Western Australia
    Old 01-18-2009, 08:30 AM   #4
    My Year: 2006
    Send Vilanova:
    Thanks Mikey and Tony for your replies. I'll try the things you suggested. I have cleaned up the small vent before for the speedo and it worked for a few days but as soon as she's back in the sea it seems to get bunged up very quickly again so I've given up trying now apart from when she's lifted out for antifouling annually.
    « Rx181 | Smart Tabs »
    new sx18 shilo Introductions 22 01-18-2009 09:09 AM
    gauge problems Talari 240z Bolo913 Mercury MerCruiser 1 11-06-2008 03:11 PM
    “Minor” problems with fuses, trip odometer, trim gauge scotty65 Original Mariah Talk 7 05-31-2008 11:35 PM
    New owner with some problems n(throttle,temp gauge,etc) jasfiveo Original Mariah Talk 2 05-20-2008 02:46 PM
    There are 338 users
