prop question
Prop Talk
Old 09-29-2013, 02:50 PM   #1
jsewall82's Avatar
jsewall82 is currently offline
My Model: z210
My Engine: 5.7L
Gallery Images: 17
Send jsewall82:
Default prop question
I purchased a 4 blade 20 pitch prop n it runs great but at WOT I am only getting about 38mph verified on gps. Any suggestions?
  • Old 09-30-2013, 01:59 AM   #2
    Default Re: prop question
    What is WOT with the 4 blade?
    4 blades ain't for speed , just low and mid range torque.
    Sounds like maybe a little "too much" prop on the lower end side for the 5.7L.
    Old 10-01-2013, 04:19 PM   #3
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    I guess my question is what should I expect speed wise out of my 4 blade. I pull skiers in a regular basis and was wondering if it is worth it to transition to a 3 blade when going "sight seeing on lake"
    Old 10-01-2013, 05:32 PM   #4
    That 4 blade prop should have you up well into the 40's...
    Old 10-01-2013, 07:07 PM   #5
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Wonder why it's not getting me there. I did notice when I returned home that the prop was a little loose.
    Old 10-02-2013, 12:37 AM   #6
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    How many rpm is it turning at wot?
    Old 10-02-2013, 07:36 PM   #7
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    It's been a few months but I wanna say I was running about 4300-4500 rpms.
    Old 10-02-2013, 09:10 PM   #8
    You might want to double check your performance numbers/rpms then just to be sure. I believe the WOT range for your motor is 4200-4600 with 4600 being the 'sweet spot'.
    There are a number of things to check if your top speed is too low but your rpms are okay. Borrow another similar prop (19" or 21" will do) & see what the boat does. Check your prop for deformed blades, do a compression test on each of the cylinders, do a tuneup if needed, check the timing, check for a build up of grunge on the hull (surprising how much that can affect your performance), has the outdrive been changed at some point? possibly the wrong gear ratio?. I'm sure others can chime in with a few more things to check.
    Old 10-04-2013, 08:17 PM   #9
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    Boat mechanically is great. The prop was lose when I pulled it out. Do you think that coulda been the reason?
    Oh no not another Prop, WOT, RPM Question Maddog Prop Talk 10 08-18-2011 02:47 AM
    Prop question ? karmann Prop Talk 4 09-04-2010 04:04 AM
    prop question joel84 Prop Talk 0 05-22-2010 02:01 AM
    Prop Question karmann Prop Talk 5 08-05-2009 02:27 AM
    Prop Question ? karmann Prop Talk 8 07-01-2009 09:20 PM
    There are 252 users
