Prop Question
Prop Talk
Old 07-23-2009, 07:12 PM   #1
karmann is currently offline
Send karmann:
Default Prop Question
Hello All
My 95 barchetta is using a SS 15 1/4" x 21 pitch prop.
It works good on top end & the RPM's seem good, max 4400 @ 50mph.
It could use a little more Dig on take off. Could I use a 4 blade prop? If so, do you stay with the same size & pitch?
thanks for any responses.
  • Old 07-23-2009, 11:44 PM   #2
    22empire is currently offline
    My Model: 2000 Shabah 183 4.3L Alpha
    Send 22empire:
    Default Re: Prop Question
    I just bought a 14.25" X 19P.. Guess I will see how it goes.. . I am definately looking for lower end grunt.. One quick question though.. Does the 4.3L EFI have a rev limiter on it? My Tach is um.. on vacation and I don't want to over rev the boat...
    I guess I should have mentioned it was a 4 -blader..
    Old 07-24-2009, 12:12 AM   #3
    difran25's Avatar
    difran25 is currently offline
    My Model: 1996 Talari 215 5.7L A1
    Gallery Images: 9
    Send difran25:
    i had a 14.5 x 19p and it was good for top end and maybe one person on the boat for a hole shot. i switched to a 14 x20p 4 blade.it pops out a lot better and stays on plane at lowers speeds. it is way better for me. would recomend.
    Old 07-24-2009, 12:23 AM   #4
    JohnZ202's Avatar
    JohnZ202 is currently offline
    My Model: 1998 Z202 Shabah
    Send JohnZ202:
    What did it do to your top end speed?
    Old 08-03-2009, 11:35 PM   #5
    Send 22empire:
    Just got back from our week away with the new prop 14.25" X 19" 4 blader. Hit 50mph with one person. And it pulls the tube and skiiers great.. It did reduce the gas mileage. It also reduced the required plaining speed. Which was great for the kids..
    Old 08-05-2009, 02:27 AM   #6
    Originally Posted by karmann View Post
    Hello All
    I had the same prop as you and switched to a 20" - 4 blade SS Michigan Wheel "Apollo" which made a significant positive difference in the boat's performance. My WOT rpms are now at 4850 with a top end of 48-49 mph (speedo) but a big increase in low - mid range punch just as difran25 noted.
    Yet another prop question Mike S Prop Talk 6 06-05-2010 01:35 AM
    Prop Question ? karmann Prop Talk 8 07-01-2009 09:20 PM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    Just another prop question MtTalari Prop Talk 8 07-25-2008 02:41 AM
    another prop question mariah2350sc Prop Talk 8 07-17-2008 03:45 AM
    There are 244 users
