SX19 Prop and Trim Question
Prop Talk
Old 06-21-2011, 04:53 PM   #1
dwymer64 is currently offline
My Year: 2007
My Model: SX19
My Engine: 4.3L
Send dwymer64:
Default SX19 Prop and Trim Question
I have an 07 SX19 with the 4.3 190hp engine. We had it out last weekend and with only 2 people at WOT it was running 41 mph at 5000 rpm. I also have to trim the motor up to a little over half to get it running the smoothest and fastest. Is this normal?
I trim it all the way down for take off and then as it gets up to speed it feels like the outdrive is dragging and putting extra load on the motor so I trim it up and it starts to "skim" on the water and pick up speed. The motor smooths out as well but if we have to stop suddenly for another boat or if someone we are following slows down, it won't take off well unless I lower the trim back down.
I love to way it rides, but I'm not not sure I should have to do so much trimming to it. I have a 14x19 alum prop that I need to replace and am thinking of going to a 21 degree pitch. Any help from you seasoned veterans would be greatly appreciated.
Dave
  • Old 06-21-2011, 07:17 PM   #2
    Default Re: SX19 Prop and Trim Question
    Something isn't right with your performance and going to a 21" prop will not solve it. Your WOT rpms are about right with a 19" prop. What your are experiencing seems to be a somewhat common problem this year in reading back thru the threads. I would have the prop checked or borrow another one to try out before spending the $$ on a new one.
    Old 06-21-2011, 07:36 PM   #3
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Yes if you back iff the throttle while your trimmed up for max speed most boats will start to plow causing you to have to get back on the throttle hard and even trim down again to get back on plane. I think you would benefit from a ss prop but you are at the right pitch and size the main thing you will gain with the ss is no flex under hard throttle and generally a bit better finish so you so you will get a smooth spin less drag if this helps at all.
    darkcalling
    Z 278 Limited
    Old 06-22-2011, 01:16 AM   #4
    Originally Posted by darkcalling View Post
    Yes if you drop speed to low while your trimmed up for max speed most boats will start to plow causing you to have to get back on the throttle hard and even trim down again to get back on plane I think you would benefit from a ss prop but you are at the right pitch and size the main thing you will gain with the ss is no flex under hard throttle and generally a bit better finish so you so you will get a smooth spin less drag if this helps at all.
    huh??
    Old 06-22-2011, 06:15 AM   #5
    Gallery Images: 3
    Send darkcalling:
    The finish on the stainless is alot better.
    darkcalling
    Z 278 Limited
    Prop trim and gauge problem Vilanova General Maintenance 10 04-20-2011 01:05 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    TRIM GAUGE INSTRUCTION Question? spinks99 Mercury MerCruiser 5 05-26-2010 02:50 PM
    4.3 Mercruiser MPI SX19 factory prop question Electrosilver Prop Talk 4 03-21-2010 03:45 AM
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    There are 345 users
