What Pitch Prop?
Prop Talk
Old 08-14-2010, 02:44 AM   #1
ggrims is currently offline
My Model: Shabah
My Engine: 350 magnum
Gallery Images: 2
Send ggrims:
Default What Pitch Prop?
Hey there, Question is what is the pitch on the prop for a 1992 Mariah Shabah 198Z with the 350 magnum,, the reason I am asking is,, welll .. Well the last of the problems came to me today as I tried to plane the boat and almost hit redline at about 5 mph,, I asssume a spun hub in the stainless prop. I am going to go aluminum for reasons of I am not looking to win a race.. I will most likely have the stainless prop reconditioned and kept as a spare. I use the boat mostly in a shallow bay area and the chance of hitting something is very real. Thanks in advance!!
  • Old 08-15-2010, 03:30 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: What Pitch Prop?
    I'd try replacing the hub on the stainless first. The flow-torq hub on merc props is replaceable.
    I have a similar sized boat and power package. I run a stainless 3 blade 14x21P. It gives me very good all around performance. My backup is an aluminum of the same spec. Where I run I have little fear of hitting bottom!
    My Mariah
    Old 09-04-2010, 04:11 AM   #3
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    some of the ss props can be replaced with a hub kit after the rubber is pressed out. some.. also if you are going to a aluminum go to a 4 blade with one pitch up . 19p ss then 20 aluminum. just remember you should be able to trim the boat more as the 4 bllade will keep the bow down.
    Prop Pitch? borz170 Prop Talk 16 01-16-2022 05:17 PM
    What prop pitch are you using for a 272 bblauvelt Prop Talk 4 07-11-2013 09:49 PM
    What is the best pitch prop to run? Buddy Prop Talk 7 08-10-2010 02:31 AM
    prop size and pitch Bill Ress Prop Talk 1 07-12-2010 02:08 AM
    23 pitch mirage plus? lance Prop Talk 1 08-18-2009 09:26 PM
    There are 257 users
