What prop pitch are you using for a 272
Prop Talk
Old 10-29-2008, 11:36 PM   #1
bblauvelt is currently offline
Send bblauvelt:
Default What prop pitch are you using for a 272
I currently have 26 and I'm looking to see if there are options other then stainless. Ideally I'd like to go composite, but I'm not real hopeful as it seems all bravo iii options are stainless.
  • Old 10-30-2008, 02:47 AM   #2
    imho.....composites are crappy and good only for a spare. They flex far more than Stainless or aluminum and any impact means replacement is required. The only positive thing i can say about them is that they are cheap. Stainless or aluminum would be my choices.
    As for the pitch....how does your boat perform with the 26? (mph & rpm's at wot). If you are within the recommended range for your motor then you could make some minor changes to gain a little more oomph or top end depending on the above info.
    Old 10-30-2008, 09:21 AM   #3
    Hi bblauvelt,
    I have the Bravo III as well and yes, the prop selection isn't even close to what the single prop outdrives have but don't feel down and out, there are benefits to our outdrive the the single props don't have.
    As Mikey said, no no to composites... and besides, I don't believe there is a set for our drives anyway. He's also right about how your current performance is with the 26 props. We do have a little leeway with diameter and pitch so exactly what are you looking for, better takeoff and planning or better cruising and top end?
    Old 07-11-2013, 08:28 PM   #4
    beth1096 is currently offline
    Send beth1096:
    Default Re: What prop pitch are you using for a 272
    I have a 22 ft talari 1994 or 1995. I just replaced the 454 and am looking for the right prop to get out of the hole. I am not sure what a WOB is.... I do have a bravo II and it is a merc enging big block...
    Any generic thoughts?
    Beth
    Old 07-11-2013, 09:49 PM   #5
    Beth
    I do actually. This is a 5 year old thread that has nothing to do with your query other than they both involved prop selection.
    As for your query. We will need to know what prop is on your boat now and preferably what your RPM's and top speed were at WOT. I'm not sure what "WOB" is either unless you meant "WOT" which stands for Wide Open Throttle and i believe the recommended range for your 454 is 4800 - 5200 rpms at WOT. I'm going to suggest that you read either or both of the first two 'stickys' at the top of the Prop forum so that you understand what is needed to determine which prop to buy.
    SX19 won't start and high pitch warning(?) noise 06_19SX Sea Fox - Mariah Talk 13 08-26-2023 01:26 AM
    Prop Pitch? borz170 Prop Talk 16 01-16-2022 05:17 PM
    another prop ? jmlanter Prop Talk 13 08-30-2008 12:18 PM
    Changing prop! Lars Prop Talk 8 07-04-2008 05:37 PM
    Z308 - Pitch and Engine question! topgunwolf Mercury MerCruiser 0 04-25-2008 10:42 PM
    There are 243 users
