Prop Pitch?
Prop Talk
Old 03-29-2008, 05:36 PM   #1
borz170 is currently offline
My Model: 1999 Mariah 18' 4.3 alpha 1
Send borz170:
Default Prop Pitch?
I'm in need of a prop for a 1999 18' Mariah (I Don't know what model it is), 4.3 Mercruiser Alpha one. Does anyone have a suggestion as to what pitch would be correct for this boat?
Mike
  • Old 03-29-2008, 06:41 PM   #2
    KSP181's Avatar
    KSP181 is currently offline
    My Model: 1994 Barchetta 182, 4.3L alpha 1
    Send KSP181:
    Mike, I have a 4.3L with the alpha 1. I think the standard equipment is a 21p 14.25 in diameter prop. There are a lot of prop websites that will give you a selection of props for your motor and outdrive combos. Good luck and let us know your progress.
    1994 Barchetta 182 - 4.3L
    Vic
    Old 03-29-2008, 08:18 PM   #3
    Send borz170:
    thanks for the info.
    Old 03-29-2008, 09:57 PM   #4
    Yep, 14.25" x 21P - 3 blade aluminum is what they came standard with. A couple of us have changed over to 4 blade - 14.25" x 20p SS prop which essentially keeps your RPM's nearly the same and within the Mercruiser recommended range but provides just a little more "bite" at start and thru the mid-range. You may lose 1 - 2mph at top end though but i dont run there so dont really worry about it. There are a few here who run a 19P - 3blade also. The lower the pitch, the higher the prop rpm and the lower the top end but just ensure you stay within that 4400 - 4800rpm at WOT range.
    Here's the link to Mercury's own prop selector tool:
    http://sites.mercurymarine.com/porta..._schema=PORTAL
    Old 03-31-2008, 09:52 PM   #5
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Was a 4.3L 160hp or 190 hp in 1999?
    My brother-in law had a 1994 182 Barchetta with the 4.3L 2bbl and he ran a 21"x 14.25 Stilletto.
    I have a 1995 180 Talari and I run a 19" x 14.25 Stilletto. Therefore, same hull, same motor, same prop except for pitch.
    He could get just over 50 mph on his rig and I top out around 47 to 48mph @ 4900 rpm, just a hair over the limit. But I liked the acceleration of my rig much better.
    My boat came with a 19P aluminum prop.
    Old 04-01-2008, 02:40 AM   #6
    Paul's pretty much got the differences in those two pitches down spot on. The only other things i can think of are the differences between SS and aluminum affect prop performance and you can split that 19 - 21" difference by using a 4 blade prop at 20"pitch which should perform in the middle of those two but still get you that extra low end & mid-range oomph.
    The '99 version of the 4.3 was 190hp as far as i know.
    Old 04-01-2008, 02:14 PM   #7
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    I run a 14.25 x 19P 3 blade black max prop on my boat and I get around 33-35mph speedo. I believe the rpms were around 4500-4700rpm range. I know I had posted up this info in some old posts somewhere on here, but im not about to go searching for it.... ROFL.
    However, this summer I will be GPS clocking my boat!
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 04-01-2008, 04:04 PM   #8
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Just to clarify, my boat came with the standard 19p aluminum prop. I switched to a stainless steel Stilletto 14.25 x 19. My 4.3L Mercruiser is rated at 160hp.
    The differences I noticed with the Stainless vs aluminum were:
    1. Less prop blowout at higher trim angles.
    2. More list to port due to prop torque. I believe the aluminum prop had a smaller diameter. This was a proplem at slower planing speeds and could be remedied by by trimming out the drive.
    3. A slight increase in top end speed.
    The best thing I ever did for my boat was add Smart Tabs. It accelerates like a inboard ski boat and rides like a 20 footer.
    Old 04-01-2008, 07:08 PM   #9
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Originally Posted by Paul F View Post
    2. 2. More list to port due to prop torque. The best thing I ever did for my boat was add Smart Tabs. It accelerates like a inboard ski boat and rides like a 20 footer.
    That is really interesting Paul - thanks for that info. My SX18 had a list to port since I bought it, I have since fitted trim tabs to fix the problem.
    You are right with the ride and acceleration, I get onto plane so quickly its amazing.
    Cheers
    Tony
    Tony
    Perth, Western Australia
    Old 04-09-2008, 08:59 PM   #10
    dharby is currently offline
    My Model: 1994 Z220 Talari 350 Mag
    Send dharby:
    Default Original Prop Pitch?
    I have the 1994 z220 Talari - 350 alpha one - with original ugly old prop. I want to replace it with a pretty stainless prop, but don't know what pitch the original is (I like it's performance and don't want to get out a protractor, compass, and whatever else is needed to measure it).
    Does anyone know what pitch I have (or an easy way to measure)?
    1994 Talari z220 350 magnum
    Proper Prop Specs? steve Prop Talk 16 04-29-2009 07:50 AM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    Z308 - Pitch and Engine question! topgunwolf Mercury MerCruiser 0 04-25-2008 10:42 PM
    prop choice Acadianbasic Prop Talk 3 08-27-2007 12:18 AM
    There are 217 users
