New upholstery for sun deck/engine cover
Projects
Old 04-27-2008, 04:55 PM   #1
bdbyrnes's Avatar
bdbyrnes is currently offline
My Model: Talari z240
My Engine: 7.4L V8 - Bravo III
Gallery Images: 41
Send bdbyrnes:
Default New upholstery for sun deck/engine cover
You can see the engine cover / sun deck on my '95 is in bad shape and needs to be replaced. We kept the boat in outside storage for 2006-2007 and this damage was directly attributable to that.
This time last year I showed up at the storage yard in Pueblo only to find cigarette type burns all over hte new cover. According to the storage yard at the Marina they had burned tumbleweeds --- but it 'couldn't have been {them}'.
We now keep her in a garage year around and this is the first of many projects I have scheduled for the summer.
Brent
1995 Talari Z240
7.4L Merc, Bravo III Outdrive
Corsa Performance Captains Call Exhaust
Samson Sports Tower
  • Old 05-19-2008, 02:34 AM   #2
    bdbyrnes's Avatar
    Gallery Images: 41
    Send bdbyrnes:
    I received back my reupholstered sundeck/engine cover. After cleaning the shelf above the engine with Mr. Clean pads (thanks for the tip on the forum!) with the help of my Dad I reinstalled the new cover. I am very pleased with the outcome.
    $915 total.
    Brent
    1995 Talari Z240
    Samson Sports Tower
    Old 05-19-2008, 12:37 PM   #3
    jasfiveo is currently offline
    My Model: 1994 Talari 220Z 7.4L Bravo III
    Send jasfiveo:
    Looks really good. I have a 1994 220Z and need to do the same thing. But with that kind of money I will have to wait one more season.
    Old 06-06-2008, 12:11 AM   #4
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    That looks outstanding!! I'm jealous....that will be next years project....
    Doug
    95 Z240 Talari, 502, Bravo 3
    Old 06-06-2008, 05:13 PM   #5
    Mariah_in_636 is currently offline
    My Model: 1999 Shabah 252 with 7.4MPI and Bravo III
    Gallery Images: 4
    Send Mariah_in_636:
    looks nice.
    Old 12-04-2008, 01:18 PM   #6
    ckgreenman's Avatar
    ckgreenman is currently offline
    My Model: 1996 Talari 209
    Send ckgreenman:
    Yours looks wonderful compared to my entire interior. Too many years in the desert (NV) without a cover (before we owner her) is the culprit I'm thinking. Not to mention we had a really bad hail storm about 2 years ago which dealt the final blow. Pretty much every surface in the boat has some sort of spider cracking like you show in your pic. Our back deck looks a dog tore it up or something. I'm currently trying to save up enough to buy the fabric needed to redo the entire interior.
    Old 03-21-2009, 09:49 PM   #7
    95 Z240 Talari's Avatar
    95 Z240 Talari is currently offline
    My Model: 1995 Z240 Talari 7.4L Bravo I Merc
    Send 95 Z240 Talari:
    Default Re: New upholstery for sun deck/engine cover
    My Boat is currently in the Upholstery shop to get the Sun Deck and the Rear Bench Reupholstered. (The heavy traffic areas)
    I ordered enough of the Original Material with the Prefixx Protective Finish, from Omnova Solutions to redo the entire interior. I am replacing it over 2 seasons to help offset the cost of the Material all at one time.
    The small samples of material matched up pretty well so I am anxious to see how well a bigger piece matches up. My boat has been stored indoors but I'm sure there will still be some fading compared to the new material. This will be a good test to see how well it has held its original color since 1995.
    The material should be in early this week so I will let you know.
    If anyone is interested in seeing or purchasing material from Omnova, let me know. I had to order at minimum a Full Roll of Material to set up an Account with them. After the suppliers they referred me to sent samples (supposedly of the same Material) that was not nearly as heavy in weght as the factory sent, I decided to through the Factory.
    Their Web Site is very helpful and they do show the different colors and styles of materal that they still make.
    Thanks to the Forum for having this info available.
    Mike
    denverjunkyard likes this.
    Thank you 95 Z240 Talari for this useful post!
    davz212 (10-30-2010)
    Old 04-01-2009, 11:21 PM   #8
    Just got my boat back today from the upholstery shop.
    I went back with the Original Omnova Prefixx Material.
    Below are some berfore and after pictures of the areas I had redone.
    Old 04-02-2009, 09:48 AM   #9
    tet68's Avatar
    tet68 is currently offline
    My Model: Mariah Z202 1999 Mercr
    Send tet68:
    Very nice!!!!!:wink_thumbup
    How did you know what uphulstery was used???
    Old 04-02-2009, 11:38 AM   #10
    The fabric is called Nautolex with Prefixx and is manufactured by a company called Omnova Products. Be aware though, Mariah used a fabric weight that was over 3x more thick than all other boat manufacturers, I believe it was 64oz while everyone else was using around 18oz.
    I don't think you can purchase it as a consumer, but your local upholstery place should be able to pick it up. Just be aware, it's probably a bit more expensive than standard replacement vinyl, but if you want a true OEM quality, go with the Nautolex with Prefixx.
    The Prefixx coating allows it to be cleaned with a mixture of acetone and water, pure acetone is only recommended for very bad stains. There's reading material available on Omnova's website.
    This was in an earlier post by Shabah Z250 and I went from there.
    If you are interested in purchasing material and need some help, contact me and I can give you the persons name that I worked with. They were very helpful and even sent out samples for me to match up the colors.
    I'll let you know that I had to create an account and order a full roll of material in order to purchase from them.
    Mike
    Upholstery Question jmills224 Original Mariah Talk 16 09-25-2015 04:47 PM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    check out this engine cover 180diablo Chit Chat/Off-Topic 17 04-04-2008 08:43 PM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    There are 277 users
