Interior project
Old 08-17-2014, 07:33 PM   #1
mrzogs21 is currently offline
My Model: Z209 Talari
My Engine: 5.7L BravoI
Send mrzogs21:
Default Interior project
I have a 96 Mariah Talari with both handles in the back by the bench seat that are loose, but could not reach the nut on the backside. Was also thinking about putting some additional speakers in the back. I was wondering if anybody knows how to get the inner fiberglass removed or at least loosened to get behind it and work.
  • Old 08-26-2014, 12:25 PM   #2
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    Default Re: Interior project
    I have a 96 z240 talari and if it's similar to mine, it is quite a chore to pull the panels loose. The upholstered top rail will have to be removed. There should be a screw at the front and back ends under a trim button, take those two out and the rail should lift right up. The floor trim will have to come off also, and the screws are drilled they the carpet and are tricky to find. You may be able to just loosen them enough to pull the panel out some to reach the nuts in the handles.
    my new project jknotts Projects 6 08-14-2013 04:01 PM
    project Oregondunes Mariah Boats For Sale & Wanted 7 01-08-2013 05:45 PM
    Buffing it out project klattu Projects 2 11-17-2011 05:29 PM
    New Stereo Project Kitto Projects 6 07-13-2011 02:52 PM
    Possible Headrest Project Kitto Original Mariah Talk 8 03-07-2011 09:56 PM
    There are 304 users
