Electrical starting problems
Old 08-10-2014, 02:03 PM   #1
Wong is currently offline
My Model: 182 shabah
My Engine: 4.3 alpha drive
Send Wong:
Question Electrical starting problems
Shabah 182 won't start. No electrical power. Except power trim works. Therefor not battery issue.
No power to gages or radio.
Replaced ignition switch but that didn't fix the problem.
  • Old 08-10-2014, 02:41 PM   #2
    Default Re: Electrical starting problems
    I'm assuming you are asking for help here..... First thing to check is your ground. Follow the groundwire from the battery, take the connections apart, clean and reconnect. There should also be a ground block on the transom near the battery that can be cleaned. Bad grounds / poor connections are the usual cause of these problems. You can also check the fuse block up underneath the console.
    Old 08-11-2014, 05:19 AM   #3
    Send Wong:
    Did this. Still wont start
    Old 08-11-2014, 02:47 PM   #4
    As mikey said..................connection issue.
    Take apart the main wiring harness plug that runs to the front of the boat and clean the connections , use dielectric grease , plug back together.
    Kinda hard to help when your responses are short with no real info as to the symptoms of the problem.
    Old 08-17-2014, 10:43 PM   #5
    allz28's Avatar
    allz28 is currently offline
    My Model: z210 Shabah
    My Engine: 5.7L Merc
    Send allz28:
    Try bypassing the push button circuit breaker. On my 5.7l it's right on top of the engine. When mine went bad, I had the exact same symptoms: no power to starter, but I could raise and lower my lower unit.
    1996 z210 Shabah
    5.7L Merc/Alpha 1
    Old 08-18-2014, 03:07 AM   #6
    That's a possibility too. This from the Mercruiser manual:
    1 A circuit breaker provides protection for engine wiring harness
    and instrumentation power lead. Reset by pushing RESET button.
    In an emergency, when engine must be operated and cause for high
    current draw cannot be located and corrected, turn OFF or
    disconnect all accessories connected to engine and instrumentation
    wiring.
    Reset circuit breaker. If breaker will not reset, electrical overload has
    not been eliminated. Further checks must be made on electrical
    system.
    2 A 20 amp fuse may be located in ignition switch “I” terminal lead
    to protect electrical system. Check for blown fuse if key is turned to
    START and nothing happens (and circuit breaker is not tripped).
    allz28 likes this.
    Old 08-25-2014, 05:00 PM   #7
    Send Wong:
    This weekend , after trying everything I could think of, I got a mechanic to look at it. He figured out that it was the 90 amp Mallory starter fuse. Going to replace this next weekend. Looks like I have the answer.
    shabah electrical
    Electrical, starter clicks several times before starting ginodesico Mercury MerCruiser 12 09-12-2015 02:09 PM
    Engine starting problems wackyd1 Original Mariah Talk 2 10-14-2012 02:58 PM
    starting problems sergio1209 Original Mariah Talk 4 04-13-2012 05:59 PM
    Ongoing problems starting 454 chriscorbett Mercury MerCruiser 15 08-29-2010 03:19 AM
    Intermittent Starting Problems Weezer Original Mariah Talk 4 11-20-2009 12:12 AM
    There are 371 users
