This should be a cheap fix
Old 04-30-2014, 06:41 PM   #1
Andy b's Avatar
Andy b is currently offline
My Model: Diablo 180
Gallery Images: 9
Send Andy b:
Default This should be a cheap fix
It's only a little split
  • Old 04-30-2014, 06:42 PM   #2
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Default Re: This should be a cheap fix
    Hmmm!
    The list of parts seems to be bigger than I'd first imagined
    mikeyt likes this.
    Old 04-30-2014, 07:41 PM   #3
    Seems like it always works out that way Andy.
    I know it does when I figure it's a simple/cheap job.
    Old 04-30-2014, 09:01 PM   #4
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    What are you up to there Andy?? Is that for the thru hull exhaust??
    Old 04-30-2014, 09:34 PM   #5
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Pushing my luck.......Too far again!
    I knew I needed new manifolds/risers and had them on order, but got the itch the other weekend and went out with some friends
    When I de-winterised the motor the rusty water and Bits of rust that got blown out was bad!!!
    Everything was going fine until I went for a high speed run. The rusty manifolds blocked the risers and the increase in water pressure split the cooling pipe. The reduced water flow in the exhaust cooked the rubbers!
    All very dramatic at the time
    They will certainly help
    But not planning on fitting them ATM.
    I want to have the time to do it properly, and not rush the job......
    Which at this time of year will probably happen!
    Old 05-02-2014, 12:01 PM   #6
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    That hose can be saved with duck tape! Much cheaper...
    doaclnr
    99 Z302 8.2 DP
    Cheap 2000 Shabah Dmaxx85 Original Mariah Talk 10 05-01-2014 01:52 AM
    Z302 Shabah '00 CHEAP boatsinternational Mariah Boats For Sale & Wanted 14 08-14-2012 06:43 AM
    Cheap(er) insurance... ChicagoWeb Chit Chat/Off-Topic 15 02-21-2010 01:40 PM
    There are 298 users
