Spring Cleaning
Old 04-29-2014, 09:14 AM   #1
Shane.walker11's Avatar
Shane.walker11 is currently offline
My Model: 202
My Engine: 5.0
Send Shane.walker11:
Default Spring Cleaning
I am going to pull my Shabah 202 out of storage tomorrow and do a nice spring cleaning on it. Just need any helpful advise with the removal of oxidation and then waxing. Thanks all and happy boating season!!!
  • Old 04-29-2014, 02:18 PM   #2
    Default Re: Spring Cleaning
    I like Mequiars Resto Kit , but there are a hundred others out there.
    A lot of guys are using the 3M products with great success.
    Just say away from the wipe on wipe off crap! You'll regret it later.
    "All good things require elbow grease" , or something like that.
    Motoxxx43 (04-30-2014)
    Old 04-29-2014, 05:46 PM   #3
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    How bad is the oxidation. If the gel coat is flat instead of gloss, wet sand with 3000 grit, you can buy a sheet of it or two at autozone. Then use a buffer with the mequires ultimate compound and finish with ultimate polish then wax or just their carnuba polishing wax. That's what I did and it took my boat from flat to full gloss! It was work, but we'll worth it!!
    Bgiltnan likes this.
    Old 04-29-2014, 05:47 PM   #4
    +1 Meguiars Fiberglass Restoration Kit.
    Old 04-29-2014, 05:50 PM   #5
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    If it's still glossy but not as shiny as you'd like. I would skip the 3000 grit. However the benefi and of using a high speed buffer with good pads cannot be understated... It translates to less work and a higher gloss, more even shine!
    Old 05-01-2014, 07:52 PM   #6
    My Model: 202
    My Engine: 5.0
    Thanks guys!! I am a little scared of the sanding part but i am definitely going to use the compound and then wax with high speed buffer!
    Old 05-01-2014, 08:34 PM   #7
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Don't let the sanding scare you if it needs done. Hi speed buffing with the Meguiars Ultimate Compound will take out any scratches from wet sanding with 3000 grit sandpaper. If it is shocking sanding with 3000 is the way to go to avoid buffing over and over and over. Just my 2 cents, be sure to post some before and after pictures so we all can see the fruits of your labor!
    Spring? mikeyt Chit Chat/Off-Topic 9 05-01-2014 05:20 AM
    Pre spring Joy Brian General Maintenance 3 03-20-2010 01:10 PM
    Spring Startup Help Corndog General Maintenance 7 02-18-2009 12:04 AM
    Spring tuneup 180diablo General Maintenance 13 05-23-2008 07:41 PM
    It's spring time ! 180diablo Chit Chat/Off-Topic 10 04-09-2008 09:16 PM
    There are 268 users
