Barchetta weight
Old 08-28-2013, 05:09 PM   #11
vman's Avatar
vman is currently offline
My Model: Z22 Talari
My Engine: 7.4 Bravo III
Gallery Images: 4
Send vman:
Default Re: Barchetta weight
Originally Posted by Motoxxx43 View Post
No disrespect taken! I'm very aware of the newer 1500/150 trucks and their car-like ratios. I believe I went on a rant with you a few months ago about the 3.73s. Have you looked at the 2014 GM pickups? Its an even lower ratio yet again. 3.08, 3.23 and 3.42 are the options! I think they are making up for it in the tranny. (Dodge Ram has an 8 speed out this year). Its all about making that MPG higher. My next vehicle will be diesel, period.
As for Colorado's remark- the elevation sucks the life out of these gas motors. Wolf Creek pass was amazing at a blistering 25 mph!!
Sent from my DROID RAZR HD using Tapatalk 4
I agree totally with what you said. Everything. My next will be a diesel as well. I never use the truck except to pull my toys. Otherwise it sits. Far the record, you couldn't give me a dodge. Good looking trucks but no ass, not to mention an identity issue. Owned by Fiat, supercrews are made in Mexico etc. You wanna go fast by a chevy, wanna work horse buy a Ford. JMO
  • Old 08-28-2013, 05:21 PM   #12
    vman's Avatar
    Gallery Images: 4
    Send vman:
    No worries. I honestly didn't know what they were. I thought 11k was pretty high but what the heck do I know!?
    I get the comment " the tail wagging the dog" with my setup. Usually at a gas station by a guy pulling a huge toy hauler or the International 4 door pulling a huge Fountain on a 3 axle... The set up every working class guy can afford! (Sarcasm)
    Holy Maiaha is that your boat Moto? That is freaken awesome.
    Old 08-28-2013, 05:30 PM   #13
    And my truck. My girlfriend has the Sierra we towed to Powell with.
    Old 08-28-2013, 11:22 PM   #14
    vman's Avatar
    Gallery Images: 4
    Send vman:
    Very nice set up.
    Old 08-28-2013, 11:25 PM   #15
    vman's Avatar
    Gallery Images: 4
    Send vman:
    According to nada the Barchette weighs in at 5650pds dry weight. So with the trailer I think I can handle it.
    Old 08-28-2013, 11:32 PM   #16
    I use NADA. A heads up though, the brochure on this forum for the boat is the accurate weight. Mariah made the boat, they know the weight. I would suggest you go off that weight. Again, that's my opinion. NADA may not be accurate. Plus trailer weight...
    Old 08-29-2013, 02:33 AM   #17
    finleydj is currently offline
    My Model: 220 talari
    My Engine: 5.7
    Send finleydj:
    Default Barchetta weight
    Great topic! I'd put my Eco-boost up against any 1/2 ton, amazing performance for what it is. I pull a talari 220 like its not there.
    Old 08-29-2013, 03:23 AM   #18
    X2,,,, plus the weight of all the little accessories, full tank of gas etc...means you are very likely at (or over) your max.... and for me, stopping is a bigger issue than pulling.
    Old 08-29-2013, 03:24 AM   #19
    X2,,,, plus the weight of all the little accessories, full tank of gas etc... and for me, stopping is a bigger issue than pulling.
    Agreed !!!
    Old 09-04-2013, 10:23 PM   #20
    vman's Avatar
    Gallery Images: 4
    Send vman:
    I was correct in the pulling weight on my truck it is 11200 pds. Here is the spec sheet on my truck, I have the 4x4 5ft bed........ 2010 Ford F150 Specs
    See also: 2010 Ford Trucks
    POWERTRAIN/CHASSIS* indicates E85 performance
    POWERTRAIN 4.6L 2V V-8 4.6L 3V EFI V-8 5.4L 3V Triton V-8
    Engine type V-8 iron block, aluminum heads V-8 iron block, aluminum heads V-8 iron block, aluminum heads
    Bore x Stroke 3.55 x 3.54 in. 3.55 x 3.55 in. 3.55 x 4.16 in
    Displacement 281 cu in, 4,606 cc 281 cu in, 4,606 cc 330 cu in, 5,400 cc
    Compression ratio 9.4:1 9.8:1 9.8:1
    Fuel Injection Sequential multiport electronic Sequential multiport electronic Sequential multiport electronic
    Valvetrain SOHC, 2 valves per cylinder SOHC, 3 valves per cylinder SOHC, 3 valves per cylinder, Variable Camshaft Timing
    Power 248 hp @4,750 rpm 292 hp @ 5,700 rpm 320 hp @ 5,200 rpm* /310 hp@ 5,000 rpm
    Torque 294 ft.-lb. @ 4,000 rpm 320 ft.-lb. @4,000 rpm 390 ft.-lb. @ 3,500 rpm* /365 lb.-ft @3,500 rpm
    Oil capacity 6 qt 6 qt 7 qt
    Coolant capacity 19.7 qt 20.0 qt 20.7 qt
    Transmission type 4-speed automatic O/D (4R75E) 6-speed automatic overdrive (6R80E) 6-speed automatic overdrive (6R80E)
    Gear ratios 4-speed automatic O/D 6-speed automatic O/D 6-speed automatic O/D
    1st 2.48:1 4.17:1 4.17:1
    2nd 1.56:1 2.34:1 2.34:1
    3rd 1.00:1 1.52:1 1.52:1
    4th 0.70: 1.14:1 1.14:1
    5th - 0.86:1 0.86:1
    6th - 0.69:1 0.69:1
    Reverse 2.32:1 3.40:1 3.40:1
    Available axle ratios 3.15:1 / 3.31:1 / 3.55:1 / 3.73:1
    SUSPENSION
    Front
    4x2 Coil-on-shock, long-spindle double wishbone independent, stamped steel lower control arm
    4x4 Coil-on-shock, long-spindle double wishbone independent, stamped steel lower control arm
    Rear
    4x2 Hotchkiss-type non-independent live, leaf springs and outboard shock absorbers
    4x4 Hotchkiss-type non-independent live, leaf springs and outboard shock absorbers
    STEERING
    Type power rack-and-pinion
    Overall ratio 20.0:1 (126-in, 133-in (Raptor only), 145-in wheelbase and 157-in wheelbase with Max. Trailer Tow) 17.0:1 (157-in wheelbase without trailer tow, 163-in wheelbase)
    Turning circle,
    curb-to-curb see Dimensions and Capacities
    BRAKES
    Front 13.8X1.24 in, twin 2.13 in pistons, Non Asbestos Organic (NAO) linings
    Rear 13.7x0.79 in, single 2.00 in piston, Non Asbestos Organic (NAO) linings
    Assist type Vacuum, RSC
    WHEELS AND TIRES
    Base wheel and tires 17-in steel, P235/70R17 (4x2) and P235/75R17 (4x4)
    Largest wheel available and tires 20-in aluminum, P275/55R20 AS (4x2) and P275/55R20 AT (4x4); Harley-Davidson™ 22-in aluminum, P275/45R22 All Season BSW (4) "V" rated
    FUEL ECONOMY (city/hwy)
    4x2 4.6L 2V V-8 4-spd auto N/A
    4x2 4.6L 3V V-8 6-spd auto N/A
    4x2 5.4L V-8 6-spd auto (gas) N/A
    5.4L V-8 6-spd auto (E85) N/A
    4x4 4.6L 2V V8 4-spd auto N/A
    4x4 4.6L 3V V8 6-spd auto N/A
    4x4 5.4L V8 6-spd auto (gas) N/A
    4x4 5.4L V8 6-spd auto (E85) N/A
    DIMENSIONS AND CAPACITIES
    Regular Cab SuperCab SuperCrew
    6.5ft 8 ft. 6.5ft 8ft 5.5ft 6.5 ft.
    4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4
    EXTERIOR
    Wheelbase 125.8 125.8 144.5 144.5 144.5 144.5 163.2 163.2 144.4 144.4 156.6 156.6
    Overall length 213.1 213.1 231.7 231.7 231.7 231.7 250.3 250.3 231.7 231.7 243.7 243.7
    Overall height 74.6 74.6 76.2 76.2 71.5 75.9 75.9 76.7 74.3 76.2 74.3 76.4
    Overall width (excluding mirrors) 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9
    Track width, front 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0
    Track width, rear 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0
    Cargo box length 78.8 78.8 97.4 97.4 78.8 78.8 97.4 97.4 67.0 67.0 78.8 78.8
    Width (max) between wheels 50 50 50 50 50 50 50 50 50 50 50 50
    Inside box height 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4
    INTERIOR All dimensions are in inches unless otherwise noted.
    Seating Capacity 3 3 3 3 5/6 5/6 5/6 5/6 5/6 5/6 5/6 5/6
    Head room
    Front 41.0 41.0 41.0 41.0 41.0 41.0 41.0 41.0 41.0 41.0 41.0 41.0
    Rear -- -- 39.7 39.7 39.7 39.7 40.3 40.3 40.3 40.3
    Leg room
    Front 41.4 41.4 41.4 41.4 41.4 41.4 41.4 41.4 41.4 41.4 41.4 41.4
    Rear -- -- -- -- 33.4 33.4 33.4 33.4 43.5 43.5 43.5 43.5
    Hip room
    Front 60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5
    Rear -- -- -- -- 66.6 66.6 66.6 66.6 64.6 64.6 64.6 64.6
    Shoulder room
    Front 66.6 66.6 66.6 66.6 66.6 66.6 66.6 66.6 65.9 65.9 65.9 65.9
    Rear -- -- -- -- 66.8 66.8 66.8 66.8 65.6 65.6 65.6 65.6
    Fuel capacity (gal) 26.0 gal
    - 26.0 gal
    - 26.0 gal
    36 opt 26.0 gal
    36 opt 26.0 gal
    36 opt 36.0 gal
    -- 26.0 gal
    36 opt 36.0 gal
    -- 26.0 gal
    36 opt 36.0 gal
    -- 26.0 gal
    36 opt 36.0 gal
    Turning circle, curb-to-curb (ft) 41.7 41.7 47.0 47.0 47.0 47.0 52.3 52.3 47.0 47.0 50.4 50.4
    WEIGHT AND TOWING (Pounds)
    126 inch WB 145 inch WB 145 inch WB 163 inch WB 145 inch WB 157 inch WB
    WEIGHT (lbs.)
    Base curb weight
    4.6L 2V 4,693 4,951 4,803 5,047 5,048 5,365 - - 5,137 - 5,270 -
    4.6L 3V - 4,981 4,813 5,042 5,068 5,395 - - 5,167 5,522 5,300 5,661
    5.4L - 5,083 4,935 5,171 5,191 5,474 - - 5,295 5,624 5,372 5,744
    5.4L HD pkg - - 5,103 5,404 - - 5,485 1 5,789 1 - - - -
    Payload capacity
    4.6L 2V 1,710 1,640 1,890 1,850 1,600 1,480 - - 1,610 - 1,470 -
    4.6L 3V - 1,710 1,980 1,950 1,680 1,550 - - 1,680 1,420 1,540 1,430
    5.4L - 1,660 2,060 1,970 1,800 1,670 - - 1,750 1,510 1,670 1,540
    5.4L HD pkg - - 3,030 2,740 - - 2,660 2,350 - - - -
    GVWR
    4.6L 2V 6,450 6,650 6,750 6,950 6,700 6,900 - - 6,800 - 6,800 -
    4.6L 3V - 6,750 6,850 7,050 6,800 7,000 - - 6,900 7,000 6,900 7,150
    5.4L - 6,800 7,050 7,200 7,050 7,200 - - 7,100 7,200 7,100 7,350
    5.4L HD pkg - - 8,200 8,200 - - 8,200 1 8,200 1 - - - -
    CONVENTIONAL TOWING – Maximum Loaded Trailer Weight Ratings (lbs.)
    Regular Cab
    4x2 Regular Cab
    4x4 SuperCab
    4x2 SuperCab
    4x4 SuperCrew
    4x2 SuperCrew
    4x4/AWD
    ENGINE AXLE
    RATIO MAX.
    GCWR
    (LBS.) 126.0"
    WB 145”
    WB" 126.0"
    WB 145"
    WB 145"
    WB 163” WB 145"
    WB 163.0"
    WB 145"
    WB 157"
    WB 145"
    WB 157"
    WB
    4.6L EFI 2V V-8
    automatic 3.55 10,400
    10,600 5,400
    5,500 -
    5,300 -
    5,200 -
    5,100 -
    3.73 10,900
    11,100 5,900
    6,000 - -
    5,800 -
    5,800 -- -
    5,500 -- -
    5,700 -
    5,600 -- --
    4.6L 3V V-8
    automatic
    3.31 13,100
    13,500 --
    - 8,000
    8,100 -
    8,100 -
    8,000 -
    3.55 12,900
    13,100
    13,500
    13,600
    14,900 -- -
    8,400 7,700 -
    7,700 -
    9,500 -- -
    7,900 -- -
    9,400 -
    9,300 -
    7,700 -
    7,600
    3.73 13,300
    13,600
    15,100 -- -- 8,000 -
    8,200 -- -- -
    9,400 -- -- -- -
    9,300 -
    9,200
    5.4L 3-Valve
    Triton V-8
    automatic 3.15 13,200
    14,000 -- 8,000
    8,600 -- -- -- -
    8,500 -
    8,400 -- --
    3.31 13,000
    13,200
    14,000 -- 8,000
    7,700 -
    8,300 -- -- -- -
    8,100 -
    8,000
    3.55 13,900
    15,000
    15,200
    15,300
    15,400
    15,500 -- -
    9,800 8,600 -
    9,500 -
    9800 -- -
    9,700 -- -
    9,800 -
    9,700 -
    9,700 -
    9,600
    5.4L 3-Valve Triton V-8 Automatic w/HD 3.73 13,900
    15,000
    15,400
    15,500
    16,700
    16,900
    17,000
    17,100 -
    11,300
    - 8,600
    - 9,500
    11,300
    11,300
    11,300 -
    9,700
    11,200
    11,100
    11,300
    11,300 -
    9,600
    11,200 -
    9,500
    11,100
    Note: Maximum loaded trailer weights shown. The combined weight of the towing vehicle (including hitch, passenger, cargo) and the loaded trailer must not exceed the Gross Combination Weight Rating (GCWR).
    Note: See RV and Trailer Towing Guide for requirements, restrictions and 5th-wheel towing I just can't excede total weight of both truck and trailler of 17100 pds.
    boat weight chriskeller82 Trailering and Tow Vehicles 2 07-03-2012 10:34 PM
    Weight bisket Chit Chat/Off-Topic 8 08-06-2011 08:33 PM
    Engine Oil Weight Douglas Alderman General Maintenance 11 09-02-2010 12:04 AM
    93 Talari weight Snowaterdude Original Mariah Talk 8 02-20-2010 12:12 AM
    what is the weight eric w Original Mariah Talk 3 01-04-2010 08:15 AM
    There are 544 users
