what is the weight
Old 01-03-2010, 11:55 AM   #1
eric w is currently offline
My Model: 212z shabah
My Engine: 5.7 alpha
Send eric w:
Default what is the weight
I need to know how much my 212z shabah weighs. I'm going to buy a trailer and it will more than likely be used
  • Old 01-03-2010, 02:52 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: what is the weight
    You don't state a year, but a z212 in the 94 brochure is 2700 lbs. Likely a bit more if you got the V8. With fuel and gear you're probably closer to 4K.
    My Mariah
    Old 01-03-2010, 03:06 PM   #3
    Send eric w:
    It's a 2000 with a 5.7
    Old 01-04-2010, 08:15 AM   #4
    Hi Eric, the brochure states around 3275lbs, which I believe is for the V6, so add a about another hundred pounds for your 5.7L to be safe...
    Engine Oil Weight Douglas Alderman General Maintenance 11 09-02-2010 12:04 AM
    help-mariah davanti 275 weight?? roar82 Original Mariah Talk 2 11-10-2009 10:34 PM
    Weight of a 216z? Fuel consumption? anthonybradley Original Mariah Talk 8 11-06-2009 02:48 AM
    1996 Z235 Talari weight rssniff Original Mariah Talk 3 03-18-2009 12:02 AM
    need info on boat weight jsk9675 Original Mariah Talk 4 07-01-2008 04:29 PM
    There are 269 users
