Depth Gauge Not Working
Old 05-16-2013, 06:04 PM   #1
Dan_Talari 225's Avatar
Dan_Talari 225 is currently offline
My Model: 225 Talari
My Engine: 5.7L Bravo I
Send Dan_Talari 225:
Default Depth Gauge Not Working
Hey all, I am a new Mariah owner, as I just purchased a '96 Talari 225 (Possibly Z as it has the decals), as of right now the depth gauge flashes 0, from the research I have done it appears that it may be related to air pockets in the epoxy on the transducer? Any input would be helpful as to other possibilities or on how to troubleshoot this issue (I am not even sure where the transducer is mounted, on the back of the transom there is only a small unit that looks like a water wheel which I am assuming is for the speedometer).
Thank you,
Dan
  • Old 05-16-2013, 09:10 PM   #2
    Default Re: Depth Gauge Not Working
    This is a very common question and with a site search you will find a number of threads discussing the same problem. Transducer is likely a thru hull unit which is mounted underneath the front portion of your engine. It could be epoxied in place or it could be a sealed oil bath mount and in either situation the transducer has likely come loose and requires re-setting in its mounting position. Good luck though with the contortions required to get at the transducer....
    Old 05-16-2013, 10:40 PM   #3
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    The wheel would be for your trip monitor on the boat.
    '96 talari , depth gauge , electrical , transducer
    Depth Gauge michaeltrotta Original Mariah Talk 3 07-18-2012 07:06 PM
    Depth gauge transducer asclarch Original Mariah Talk 7 07-08-2011 02:02 AM
    HELP! Air/Sea Temp gauge not working on my 96 Z272 mikelawson Original Mariah Talk 1 06-27-2010 11:44 AM
    fuel gauge not working right Hoseman Original Mariah Talk 1 05-18-2010 02:32 AM
    Fuel gauge not working kingtide Original Mariah Talk 5 07-26-2008 06:34 PM
    There are 437 users
