New mariah owner with a few ???
Old 05-16-2013, 10:42 PM   #1
bossmustng429 is currently offline
My Model: 202 shabah
My Engine: 4.3l alpha one
Send bossmustng429:
Default New mariah owner with a few ???
Hey all, I just picked up a 98 shabah 202 with a 4.3l and alpha one and 330 hours. I got it for 2500 but the upholstery is shot..have a couple electrical demons (need to upgrade to view diagrams?) The engine runs great out of the water but when its in the water it backfires and has little acceleration..any ideas?(boat has sat for awhile) Also the trim reservoir is filled with a milky looking substance..assume water is somehow getting in? I know I need risers/manifolds because they are still the one piece..any suggestions on what/where to buy? Sorry for all the questions and I'm sure I'll have more..but any help would be greatly appreciated! Thanks!
  • Old 05-16-2013, 10:48 PM   #2
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    Default Re: New mariah owner with a few ???
    The first thing I would do is get all that old gas out of it. Dont just put new gas on top of it... Try to get as much as you can out and then put fresh gas in it.
    Old 05-16-2013, 10:52 PM   #3
    Send bossmustng429:
    Will do...planed on getting an external small tank and putting fresh gas in it and running it off that...if I can't get the tank what is the easiest/safest way to get it out of the original tank? Gauge shows about half
    Old 05-17-2013, 01:05 AM   #4
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    When you tip the back seat forward the cover on the floor in front of the engine is access to the fuel tank. You can pull the sending unit up and siphon the gas out from there. Or try to siphon from the filler but you'll need a decent sized hose.
    Old 05-17-2013, 01:52 AM   #5
    Welcome boss
    I'd get that drive vacuum/pressure tested ASAP. Water and gears don't get along for long.
    Here is a link to the benefits of being a paid member.
    Manifolds are around 500-700 depending on where you get them.
    I bought aluminum manifolds from this guy.
    Exhaust Manifolds
    Old 05-17-2013, 02:11 AM   #6
    Send bossmustng429:
    What all do you need for the 1 piece to 2 piece conversion? The thing I'm not sure of is the riser/elbow height and I gather you need another elbow for the conversion?
    How do you vacuum/pressure test the drive? could water be getting in at the lines going to the trim cylinders? They have a brownish/rust looking stain on them
    Tomorrow I'm draining the gas and putting fresh gas in...hopefully I can get one problem out of the way
    Old 05-17-2013, 02:51 AM   #7
    Dang ,
    The conversion kit seems a bit high. This one is the cheapest I found!!
    Manifold conversion Kit
    Old 05-17-2013, 02:54 AM   #8
    Send bossmustng429:
    Yea thats steep....there is a slightly cheaper one on mercexhaust.com....but not by much
    New Mariah Owner! - 1996 Mariah 210 Shabah Superstang Introductions 8 03-23-2013 05:00 PM
    New Mariah Owner-Low Oil Pressure/not starting Mariah SC 23 Loganwh Mercury MerCruiser 1 06-17-2012 03:00 PM
    New Mariah Owner Dick Introductions 1 05-17-2010 07:59 PM
    Mariah owner from NY MariahNY Introductions 2 08-15-2009 01:00 PM
    New Mariah Owner robin l. hazlett Original Mariah Talk 2 08-09-2009 01:37 PM
    There are 237 users
