Brand for power steering cable
Old 04-20-2013, 02:54 AM   #1
Gallery Images: 2
Send Douglas Alderman:
Default Brand for power steering cable
What brand do I look for when replacing my power steering cable. A rack and pinion steering cable?Just replaced my power steering pump for hard steering which didn't help.Going to try the cable. 1999 214 Jubille 5.0 Eng. Does anyone know what size I would need.
  • Old 04-20-2013, 02:03 PM   #2
    Default Re: Brand for power steering cable
    It is probably a rack system. Although rotary boxes are used too. Just have to look under the dash Douglas
    Also where you have a Alpha or Bravo Drive matters I believe. Which in your case is a Alpha right?
    If you look along the length of the cable it will be stamped as to the size. They are usually measured in inches for boats under 25 ft. So just as a example- if it was a 12ft cable it would be 144 inches.
    Douglas Alderman (04-20-2013)
    Old 04-21-2013, 11:49 PM   #3
    Gallery Images: 2
    Thumbs up Re: Brand for power steering cable
    Took the clevis pin out from the steering cable back of engine.The steering from the steering wheel was still hard to move.Have to replace the cable. Turned off the big nut and pulled the shaft thru.Tied a strong string to end of cable longer then boat.Took off 4 bolts holding rack on behind steering wheel.Had yo take off throttle control lever to expose cables. Found out steering cable was held inplace with plastic ties wraped around electrical wires.So had to cut them before pulling steering cable all the way out. My 214 Mariah 1999 Jubille 5.0 Ahpha cable from Teleflex is SSC13414 I had replaced the power steering first and that was not my problem.
    Old 04-22-2013, 12:19 AM   #4
    Glad to hear it worked out for you Douglas.
    I bet she turns like a dream now
    Old 04-22-2013, 12:58 AM   #5
    Gallery Images: 2
    http://us-mg6.mail.yahoo.com/ya/down...Inbox&inline=1
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    Steering cable replacement/repair? jchemotti General Maintenance 4 10-10-2016 05:57 PM
    Steering cable slop??? Steve91T Original Mariah Talk 4 09-15-2013 06:16 PM
    Please Help: Do I Need A Steering Cable?? todd0505 General Maintenance 6 01-24-2013 12:24 AM
    Z252 Steering Cable edward cossey Original Mariah Talk 0 04-19-2010 06:15 PM
    There are 311 users
