Steering cable slop???
Old 04-24-2012, 09:28 PM   #1
Steve91T is currently offline
My Model: Z202
My Engine: 5.7 Alpha 1
Send Steve91T:
Default Steering cable slop???
Hello all, I'm doing some spring maintenance to the 95 Z202 before we get it on the water. One that that I'm trying to address is my sloppy steering wheel along with heavy steering.
I've been doing a lot of poking around and found if I disconnect the pin that connects the drive lever to the steering ram, the steering is still stiff, but the drive swings freely. If I pull the pin that connects the steering cable to the ram, the steering is free and smooth, but it still has the slop.
The slop that I'm talking about is from about 11-1 o'clock, or about 1/8 of a turn.
I would think that if the cable needed to be replaced that it would be tough to turn while disconnected, but this isn't the case. Is there somewhere to make an adjustment? What at the steering wheel itself, what can I check?
Thanks guys!
Steve
  • Old 09-12-2013, 02:08 PM   #2
    Hrdcor is currently offline
    My Model: Shabah 210
    My Engine: 5.7 bravo 3
    Send Hrdcor:
    Default Re: Steering cable slop???
    I have the same question ... Does any one have an answer to this ???
    Old 09-14-2013, 07:29 PM   #3
    Send Hrdcor:
    Bump... Any body ??? I really would like to know if there is an adjustment to take out the slack out of the steering ???
    Old 09-14-2013, 08:36 PM   #4
    Steering bell crank loose or worn/bushings worn , steering actuator pins worn , worn gimble ring assembly , worn cable assembly maybe.
    Just a few things that come to mind guys.
    Old 09-15-2013, 06:16 PM   #5
    Send Hrdcor:
    Thank you so much ... I will check these items an report back my findings .
    2000 Z260 Steering Cable sean77atx Original Mariah Talk 6 09-06-2022 08:56 PM
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    96 shabah steering cable stuck gman Original Mariah Talk 0 06-05-2011 02:09 AM
    1998 214 jubilee steering cable smeier Original Mariah Talk 1 04-11-2011 10:04 PM
    Z252 Steering Cable edward cossey Original Mariah Talk 0 04-19-2010 06:15 PM
    There are 375 users
