Please Help: Do I Need A Steering Cable??
General Maintenance
Old 01-23-2013, 09:41 PM   #1
todd0505 is currently offline
My Model: 182 Shabah
My Engine: 3.0L MerCruiser
Send todd0505:
Default Please Help: Do I Need A Steering Cable??
Hello everyone, first post here I really hope you guys can help..
The Steering on my 1999 Shabah 182 has become incredibly difficult. Out of the water it isnt too difficult to turn but in the water even at almost idling speed it is very very hard to turn. I have read around on here a bit and it looks like there could be a few different problems. Any advice will help at this point!!!
  • Old 01-23-2013, 09:44 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Please Help: Do I Need A Steering Cable??
    have you checked your power steering fluid level, and belt tension
    Old 01-23-2013, 09:49 PM   #3
    Send todd0505:
    The fluid is good but I am not familiar with how to check the belt tension?? Sorry I'm pretty new to this
    Old 01-23-2013, 09:59 PM   #4
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    It would help if you tell us what motor have you got.
    but as a rule there should be about a 1/4 inch belt deflction on the 3.0L and 1/2 inch on the V6 and V8's
    it may help if you bleed the system by running the engine and doing several lock to lock turns.
    Old 01-23-2013, 10:12 PM   #5
    Send todd0505:
    Oh yes, I have a 3.0L Ill check the tension and try bleeding it. Is there a way to know for sure (or hopefully rule out) if I need a new cable?
    Old 01-23-2013, 10:21 PM   #6
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    you could disconnect the cable at the motor end and try the wheel...
    Old 01-24-2013, 12:24 AM   #7
    The bottom line about steering cables is this.
    99% have two 90 degree bends in them. The tighter the bends (typically the smaller the boat the tighter the bend) the quicker they wear out. 90 % of hard steering is due to wear at the bends of the steering cable. The other 10% is due to several other issues.
    The cables are designed to fail after time. There is no lubrication abilities so they are what they are.
    If you remove the clevis pin at the cable end at the transom assembly where the steering cable ends and the outdrive moves easily left and right the it is usually the cable.
    I have never seen a power steering unit cause hard steering (thats just me). I have seen them cause steering issues but not consistant hard steering. Some cable can last many years. Some last very few.
    Have a look at this link at boatfix.com for diagrams & instructions regarding your steering cable.
    2000 Z260 Steering Cable sean77atx Original Mariah Talk 6 09-06-2022 08:56 PM
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    Steering cable replacement/repair? jchemotti General Maintenance 4 10-10-2016 05:57 PM
    Steering cable slop??? Steve91T Original Mariah Talk 4 09-15-2013 06:16 PM
    Z252 Steering Cable edward cossey Original Mariah Talk 0 04-19-2010 06:15 PM
    There are 266 users
