My new 1993 2200Z
Old 03-12-2013, 07:23 AM   #1
Dark14ry is currently offline
My Model: 2200Z
My Engine: 5.7L 350 MerCruiser
Send Dark14ry:
Default My new 1993 2200Z
Hey everyone, I just bought my 1st boat and was excited to see Mariah has a strong following and an actual owners club, where I can turn to as a 1st time boat owner.
My 1st question for you is probably really basic, but because I have never owned a boat, it's something I don't know.
On my instrument panel, I have 6 rubber coated switches on each side of my steering wheel. I need to replace them because it rubber has become "gummy" if that makes sense. If you push in them, the rubber will pretty much leave resin on your fingers.
I don't even know what these switches are called for me to look them up on the parts retailers page.
Can someone help a 1st timer out? Thanks
It's a ROCKER SWITCH!!! Ok now can someone tell me, are these something that can easily be swapped out?
1993 Mariah 2200Z 5.7L 350 MerCruiser
  • Old 03-12-2013, 11:01 AM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Yes, the rocker portion of the switch is super easy to change. The switch is the part underneath your dash with the wires connected to it, and the actuator is the part that you need to replace. I just replaced all my actuators last year, and it is really easy. The first thing you need is a tool to release them that looks like this....
    The tool slides underneath the actuator and just pops right off. Then just snap the new one in place and you are good to go. There are several types of actuators out there. You can get them screen printed or just look for ones that are already labeled. Some actuators are not lit, so at night you really can't see what the switch is for. So make sure that you get the same kind as you had or better. Take an actuator off and see if your switch underneath has 1 lite or 2. This will tell you what kind of "lens" to get in your actuator.(ie, is there only a small lens on the bottom or one at the bottom and another on the top for the lite underneath to shine through)
    As far as where to get them....try eBay. There are always a bunch on there.
    File Type: jpg ImageUploadedByTapatalk HD1363085690.909468.jpg (2.6 KB, 6 views)
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 03-12-2013, 01:28 PM   #3
    Default Re: My new 1993 2200Z
    Chris hit it right on the head.
    The actuators are super easy to change and will definately improve the look of your dash panel.
    Old 03-12-2013, 03:32 PM   #4
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    By the way, here is a link to the thread I did when I redid my switches. Not sure if there is anything that is helpful in there or not. But it is a night and day change to your dash by replacing the actuators.
    Almost finished with dash
    2001 Shabah Z275 ST
    Old 03-12-2013, 08:00 PM   #5
    My Model: 2200Z
    Send Dark14ry:
    Chris,
    I checked your link and the pictures are exactly what I was talking about. Thank You so much......
    The ones you installed are the same ones that I have on my boat that need replacing.
    Do you knw what causes them to melt/rot? is it just age and wear?
    Old 03-12-2013, 08:24 PM   #6
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Your very welcome bud. As far as what causes it, I am assuming just being open to the sun. My boat has been a south florida boat since birth until we bought it so the sun here is brutal on everything. That is what I think caused mine to get tacky like yours did. I started covering my dash when we go out and are at anchor or beached. Of course, when we get new friends coming on the boat, I always remove the towel. Gotta show off the Mariah!
    2001 Shabah Z275 ST
    1993 2200Z brochure/info tstaszak Original Mariah Talk 8 09-02-2010 08:18 PM
    91' 2200z ltd-stock trim tabs? jtatum66 Original Mariah Talk 2 09-02-2010 05:22 PM
    1993 Mariah 2200Z tstaszak Introductions 1 08-19-2010 02:17 AM
    1991 2200z ltd-test run-problems jtatum66 Original Mariah Talk 5 08-04-2010 03:27 PM
    1991 2200z ltd-new to me. jtatum66 Original Mariah Talk 1 07-29-2010 12:15 PM
    There are 283 users
