91' 2200z ltd-stock trim tabs?
Old 09-02-2010, 07:37 AM   #1
jtatum66 is currently offline
My Year: 1991
My Model: 2200z ltd
My Engine: 7.4 bravo 1
Send jtatum66:
Default 91' 2200z ltd-stock trim tabs?
hi members.-i have a 2200z with accu-trim tabs. i can't activate them. I think there is some kind of air bag or something that should activate the tabs all i see at the back of the tabs is a air line and nothing else-how would this work?
  • Old 09-02-2010, 10:29 AM   #2
    Default Re: 91' 2200z ltd-stock trim tabs?
    Hi jtatum66, I got to say, you have the most unusual Trim Tabs I've ever heard of, kind of a water and air combination using a bladder between the tab halves.
    I Googled them and got very little info back, so here's what I got:
    1) A member on a Boston Whaler forum stated they are/were (?) made in Sweden, but I can't seem to verify if this is correct, let alone if they're still in business (I tried several Swedish business directories with out any luck).
    2) According to this particular write-up (dated back in 2000), it seems like you're missing the control levers and associated hardware connecting the controls to the tabs. This particular owner went with the Accu-Trim Tabs for the cost savings, but later in the story, he changed them over to Bennett Tabs. Click on these links and read how the Accu Trim Tabs are supposed to work and then later why he changed them out.
    Link 1 - How they work
    Link 2 - Why they were replaced (4th and 5th paragraphs)
    If you're going to stay with Trim Tabs, I recommend replacing them with Smart Tabs (if they have a model for your hull size) otherwise, Bennett or Boat Leveler Co. Tabs for hydraulic or Lenco for pure electric.
    Good luck,
    Old 09-02-2010, 05:22 PM   #3
    My Year: 1991
    My Model: 2200z ltd
    Send jtatum66:
    thank you for your input-like you said go with the smart tabs.
    1992 2000Z and Trim Tabs hhv00586 Introductions 0 09-16-2009 08:18 PM
    trim tabs ?????????? boat man2 Original Mariah Talk 6 07-07-2009 12:07 PM
    Trim tabs: Pneumatic vs. Hydraulic & Manual vs. Automatic Soaussie Original Mariah Talk 9 06-03-2009 04:38 AM
    There are 252 users
