Buying a 94 davanti 241
Old 03-11-2013, 07:54 PM   #1
alliedasset is currently offline
My Year: 1991
My Model: diablo
My Engine: 4.3L
Send alliedasset:
Default Buying a 94 davanti 241
were buying a 94 davanti 241 with a 350 n bravo 3. the boat has 337 hours n is n really good shape. Is there anything i should be aware of or ask. This site has helped me a ton. Or if anyone has pictures or anything of there. ty Tim
  • Old 03-11-2013, 10:07 PM   #2
    Default Re: Buying a 94 davanti 241
    hi Tim,
    There isn't anything special with the Davanti that you need to watch out for other than the usual stuff like trim pieces, ensuring the electrical items all work and particularly look at the cuddy door as it will be very difficult to replace if broken.
    Old 03-12-2013, 01:54 PM   #3
    +1 with what mikeyt said. One word of advice, don't buy the boat without doing a water trial first.
    If you've got a few hundred extra to spare, you could hire a marine surveyor to go through the boat with a fine-tooth comb and give you a professional opinion. They'll check everything from the moisture levels in the hull, compression in the engine, outdrive, everything mechanical and electrical, and even as far as the bulbs in the lights.
    Good luck, and we hope to have you as part of the Mariah family soon!
    Old 03-12-2013, 06:40 PM   #4
    My Year: 1991
    My Model: diablo
    My Engine: 4.3L
    Send alliedasset:
    thank you. were buying it from a dealer and am taking my mechanic with for a water test when the weather gets warmer here n chicago, n this will be our second mariah we have a 91 diablo right know we luv the mariahs . ty
    Buying Advice Yves Sea Fox - Mariah Talk 3 10-14-2011 11:00 PM
    Buying 94 talari 210 My 210 Talari Original Mariah Talk 3 07-23-2011 11:15 PM
    buying prop eric Prop Talk 1 04-03-2010 02:51 AM
    buying a prop need help lance Original Mariah Talk 27 05-04-2009 11:34 PM
    Help with Buying flyguy972 Sea Fox - Mariah Talk 1 04-10-2009 11:01 AM
    There are 292 users
