Ignition switch replacement - W,X,Y, or Z?
Old 07-10-2012, 02:36 AM   #11
brianvander's Avatar
brianvander is currently offline
My Year: 94
My Engine: 5.7L Alpha I
Gallery Images: 7
Send brianvander:
Default Ignition switch replacement - W,X,Y, or Z?
Mine was really simple to remove, the cylinder should have a threaded ring/nut on the outer side of the dash, once that is removed the switch should just pull out the underside of the dash.
While my wires to the were not very long I laid on my back and was able to grip the switch and screwdriver remove the connections and reconnect to the switch. Reinserting the switch back into the dash was little trickier, only because you have to do it feel. But once in the hole the threaded ring went back on easily.
Cost wise, the cylinder & key was still far cheaper than 4 keys, 3 of which you can't use (then what if it's not a Mariah switch?)
BrianVander
1995 Shabah Z212 5.7
Red on Grey
  • Old 07-10-2012, 02:00 PM   #12
    Bill's Avatar
    Bill is currently offline
    My Model: Z222
    My Engine: 496 HO Bravo lll
    Send Bill:
    Default Re: Ignition switch replacement - W,X,Y, or Z?
    Thanks again Brian
    I will look at it this weekend It looks like thats my best bet is to buy a swtch and key and try that.
    Dont know if thats the answer to my problem but it should eliminate the the electronic switch as the problem I have been trying to get a mobile machanic to look at the boat But cant seem to find one to come out.
    Thanks again for you quick response and suggestion
    Regards
    Bill
    2001 Z222
    New Ignition Switch - Won't Start Dsg03svt Original Mariah Talk 6 04-11-2012 01:46 PM
    Problem with Ignition Switch lmdengler Original Mariah Talk 3 05-31-2011 12:43 AM
    Ignition switch/Switched Power/Battery Isolator jasfiveo Original Mariah Talk 3 05-04-2010 08:31 AM
    Ignition Switch - Flame Arrestor Light Roger Butterfield Mercury MerCruiser 3 04-01-2010 09:09 PM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 299 users
