Ignition Switch - Flame Arrestor Light
Old 03-15-2010, 04:45 PM   #1
Roger Butterfield is currently offline
My Model: Z280
Send Roger Butterfield:
Default Ignition Switch - Flame Arrestor Light
Hi Folks - My Z280 would not shut off when I turned the key so ended up having to shut it down by turning the battery switch off. I assume I just need to replace the ignition switch.
More importantly, the Flame Arrestor light stayed illuminated. My problem is that I can't for the life of me remember if that light (under the steering wheel) is supposed to remain on when the key is turned off or not. My assumption is that it should go off.
Could this be due to the bad ignition switch?
Roger
99' Z280 7.4L
  • Old 03-15-2010, 06:43 PM   #2
    My Model: Z280
    Default Re: Ignition Switch - Flame Arrestor Light
    Correction - It isn't the Flame Arrestor light. It's the automatic fire extinguisher light for the extinguisher in the engine compartment.
    Sorry about that :-)
    The light remained on even though my battery selector switch was all the way off. This happened when my ignition switch would not shut down the engine.
    Roger
    99' Z280 7.4L
    Old 04-01-2010, 08:26 PM   #3
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    I don't know if this is true or not, but I was told it is not good to turn the battery switch with the engine running. If it happens again I would try the kill switch first. Then go to the battery switch next if necessary.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 04-01-2010, 09:09 PM   #4
    My Model: Z280
    Thanks John - All is well now that I found a disconnected wire under the dash that lead to the auto fire extinguisher. Strange how something that small can affect something much larger.
    Roger
    99' Z280 7.4L
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    Cant find Nav Light switch gsbrebel Original Mariah Talk 6 08-12-2009 10:31 PM
    Light Switch Questions karmann Original Mariah Talk 4 07-16-2009 04:57 PM
    Light Switch karmann Original Mariah Talk 2 07-07-2009 06:41 AM
    Dashboard light switch noons28 Original Mariah Talk 1 04-20-2009 09:44 PM
    There are 418 users
