Problem with Ignition Switch
Old 05-30-2011, 11:45 PM   #1
lmdengler is currently offline
My Model: 238 Shabah
Send lmdengler:
Default Problem with Ignition Switch
We unloaded our Mariah for her maiden voyage (we purchased it in April) and sadly – the ignition key “spun”. It’s like the “gears” are stripped. It worked fine when we test started it before launching a few days earlier. Then at the dock – it turned over with a little effort. Then it stalled (which likely had nothing to do with the ignition switch) – then when we went to turn it over again – the switch just spun. It’s obvious it needs to be replaced/repaired. We can’t get to it. Any thoughts? Any thoughts on where to purchase a new one? It’s a “Y” key.
  • Old 05-31-2011, 12:07 AM   #2
    simpleaz's Avatar
    simpleaz is currently offline
    Send simpleaz:
    Default Re: Problem with Ignition Switch
    Hi Imdengler
    Sorry to hear about the key. I had an aftermarket one on my boat and bought thru the board member a 2 key and ignition switch to make it like factory. I am not sure if the gentleman has any left. I know he has keys but not sure about the switch. Search for the key and you will see a lot of posts.
    It may just be the shaft is loose and needs tightening only. I have to tighen mine a couple times a year to keep it from spinning while starting.
    As far as getting operational, hit a marine store or West Marine and you can replace the whole thing for $15. Takes about 10 minutes tops. You won't have the cool Mariah key but you can fix it low cost.
    You should be able to lay down and look under the steering wheel to see the switch assembly and the mount thru the dash.
    Not sure of your model, but i can imagine too many variables to how the switch is mounted or used.
    Good Luck.
    1996 Mariah Shabah 200 5.7L
    Old 05-31-2011, 12:34 AM   #3
    Did you look under the forum "Mariah Parts & Collectibles for Sale"? That would be your first place and then into this thread.
    Old 05-31-2011, 12:43 AM   #4
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    Did the lock cylinder spin or the complete switch? If the complete switch, it may just need to have the mount tightened.
    IowaWing
    Steve
    Ignition? inertia Introductions 0 08-02-2010 08:19 PM
    Ignition switch/Switched Power/Battery Isolator jasfiveo Original Mariah Talk 3 05-04-2010 08:31 AM
    Ignition Switch - Flame Arrestor Light Roger Butterfield Mercury MerCruiser 3 04-01-2010 09:09 PM
    Possible Ignition Problems?? Help! jeffryb Original Mariah Talk 3 09-18-2009 12:28 AM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 332 users
