Ignition switch/Switched Power/Battery Isolator
Old 04-30-2010, 09:52 PM   #1
jasfiveo is currently offline
My Model: 1994 Talari 220Z 7.4L Bravo III
Send jasfiveo:
Default Ignition switch/Switched Power/Battery Isolator
I am putting on the finishing touches on my PAC battery isolator. I have added a second battery only for the radio. My question is this....I have to run a lead to switched power. For example when the key is in the on position and the boat is running the isolator will open allowing for both batteries to charge. When the key is off or in accessory mode the isolator will close allowing the stereo to only operate off the second battery. I looked under the ignition and noticed the following wires: red, red with yellow stripe, two purples, and black. I am assuming the red is start power and the red with yellow is maybe accessory? Can somebody help me so I put the isolator turn on lead to only switched/on power. Thanks.
  • Old 05-01-2010, 10:01 PM   #2
    Send jasfiveo:
    Default Re: Ignition switch/Switched Power/Battery Isolator
    Anyone? I guess its time to get out the volt meter.
    Old 05-03-2010, 06:21 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Surprised you don't have one if you're proficient enough to setup a system like that. Sounds like it's going to be real nice. Sorry I can't help with the colors.
    Old 05-04-2010, 08:31 AM   #4
    Hi jasfiveo, if you look very closely at the back of your ignition switch I believe there are 4 terminals and they should have a very small letter next to each one:
    (Example)
    S - Start position
    A - Accessory position
    I - Ignition position
    B - Battery power in
    Just match the color wires to the terminals and that should get you going.
    Hope this helps,
    Ignition Switch - Flame Arrestor Light Roger Butterfield Mercury MerCruiser 3 04-01-2010 09:09 PM
    Battery switch location jdecoudres Sea Fox - Mariah Talk 3 03-25-2010 05:17 AM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    2nd Battery/Isolator Relay Switch jasfiveo Original Mariah Talk 11 06-04-2009 03:33 AM
    Power Seat Switch Help stereoman405 Original Mariah Talk 2 04-21-2009 08:28 PM
    There are 381 users
