Question?? Do I have to remove the motor to change the coupler??
Old 06-13-2012, 02:02 PM   #1
Karnac is currently offline
My Model: z244 jubalee
My Engine: 5.0gi
Send Karnac:
Question Question?? Do I have to remove the motor to change the coupler??
I have a jubalee 244z with a 7.4 mpi mercruiser and I need to take the motor out to change the coupler. There isnt enough room to pull the motor out as a unit do i have to disassemble the motor in the boat to get the motor out or will it come out if you turn it sideways? Does anyone have any information on this or has anyone come across this before??
  • Old 06-14-2012, 01:16 AM   #2
    mike699's Avatar
    mike699 is currently offline
    My Model: 200 Talari
    My Engine: 5.0 L Mercruiser
    Send mike699:
    Default Re: Question?? Do I have to remove the motor to change the coupler??
    The engine was installed while it was fully assembled so there has to be a way to get it out fully assembled. More than likely you need to remove some panels and cross supports to get enough access. Can you post pictures of the engine compartment?
    Old 06-18-2012, 12:56 PM   #3
    Yes it does need to be removed to repair the coupler. But the engine won't need to be disassembled, just the interior. I'm assuming your has a fiberglass lip molded above it, like the photo below?
    The easiest thing to do, is to unmount the engine off the mounts and then move it forward and lift slowly until it clears the lip and can be safely removed.
    This is a job best left up to the pros.
    How do I remove the old tachometer? RodneyWest Original Mariah Talk 8 08-27-2020 03:12 AM
    Do I have to yank the motor to change my starter? Flyboy Mercury MerCruiser 1 07-07-2010 05:42 PM
    Hydraulic trim motor question m&mmariah Boating 101 3 05-04-2010 09:06 AM
    Maybe a engine hub/coupler Teal2000Z Mercury MerCruiser 10 09-16-2008 10:15 AM
    Alpha Gen II Drive Coupler Captain Steve Mercury MerCruiser 3 10-22-2007 06:40 AM
    There are 235 users
