Low Oil Gauge/ Not starting
Old 06-11-2012, 12:47 AM   #1
Loganwh is currently offline
My Year: 2008
My Model: Sc23
My Engine: 5.0
Send Loganwh:
Default Low Oil Gauge/ Not starting
Hello, recently purchased 2008 Mariah SC23 Cuddy IO Mercruiser Alpha 1 120 hours
Just had annual maintenance *completed (water pump/oil change/new belts/carb fuel filter) by local repair shop.
Took boat out today for first time and had troule 30 mins into boating. Stopped boat to reapply sunscreen and boat would not start. Noticed alert and low oil pressure (0 psi). Boat did not appear to be overheating? Ended our day by being towed in by BoatUS.
Any idea what potential problems occurred? Would the potential problems been overlooked/caused by mechanic
  • Old 06-11-2012, 04:52 PM   #2
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Default Re: Low Oil Gauge/ Not starting
    Need a little more info to try and help. Is your boat fuel injected or does it have a carb? Did you turn off the engine or did it quit on its own? Does the engine alarm sound when you turn move the key to the on position then go off when the engine starts? Were all the gauges reading normal levels before the problem happened?
    Good luck
    Dan
    1995 Z272 Barchetta
    Old 06-11-2012, 07:48 PM   #3
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    If the engine is not running, then you will not have oil pressure. If it is running, and you have no oil pressure, then you should turn it off immediately!
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 06-17-2012, 11:55 PM   #4
    My Year: 2008
    My Model: Sc23
    My Engine: 5.0
    Send Loganwh:
    Thanks. Ended up carborator was flooding the engine causing it not to start. $400 later a rebuilt carborator and I'm back on the water. Boat= bust out another thousand
    Hard starting 4.3LX mx20 Original Mariah Talk 3 10-06-2011 11:09 AM
    Not always starting Snowaterdude Original Mariah Talk 1 09-20-2009 03:31 AM
    Starting Problem mark shumaker Original Mariah Talk 7 09-08-2009 11:03 PM
    Starting problem..... Medic574 Original Mariah Talk 7 09-01-2009 03:34 AM
    starting issues murphysocc Mercury MerCruiser 2 07-13-2009 06:36 PM
    There are 316 users
