Engine problems
Old 03-31-2012, 12:09 PM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: Engine problems
I doubt that there is anything wrong with the starter itself. It is isloated from the rest of the electrical system by the starter solenoid. I was just suggesting to double check the wiring around the starter solenoid and the starter slave solenoid as they were probably disturbed durring the starter replacement and there are connections to the ignition system. If there are no broken wires, nothing is miswired and all your voltages check out then move on to the fuel system.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
  • Old 03-31-2012, 09:02 PM   #12
    I'd take the starter to NAPA , Autozone or whoever and have it tested to start with. Are you sure that you have wires in the correct spot? Make sure all connections are clean.
    If it ran fine before you had the starter rebuilt then chances are it is something that was done during that repair. How long did it sit between when it ran fine and getting the starter rebuilt?
    This is a interesting problem please make sure to keep us advised.
    Larry
    Old 04-01-2012, 01:16 AM   #13
    truckingeorgia79's Avatar
    truckingeorgia79 is currently offline
    My Model: MX 200 Talari
    My Engine: 5.7L Alpha I
    Send truckingeorgia79:
    @ ColoradoDiablo: it only sat one week prior to having the starter problem. Next weekend I am going to check all the wires and connections on the starter, as well as following the wires back to where they go to make sure they are good. I will keep everyone updated on the status of my poor sick Mariah
    Jeremy
    1993 Mariah MX 200 Talari/ 5.7L Alpha I
    Old 04-05-2012, 10:37 PM   #14
    The day my engine quit working I took these pics while we were waiting on SeaTow. Hope you enjoy and get a laugh on my behalf...
    Jeremy
    Old 04-06-2012, 01:40 AM   #15
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    At least she had a nice soft beach!
    Zack
    1994 Z212 Shabah
    Old 04-06-2012, 04:14 PM   #16
    Well attempted to start boat this morning and what do you know it started as if nothing was wrong. Let it idle a little bit then just as the risers were starting to get warm it started to sputter then died. I attempted to restart, it started then died again. Started one more time then quickly started messing with the choke valve (closing it a little) and it stayed running. Once I let go of the choke valve it sputtered and died. So I know I have a choke problem but don't know how ot fix it. Anyone have any ideas?
    Jeremy
    Old 04-06-2012, 04:36 PM   #17
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    When it's cold is the choke closed?
    It's a bimetallic spring, easily replaced.
    Old 04-06-2012, 04:56 PM   #18
    The choke isn't fully closed. I can push down on it about 1/4 of an inch. The choke lever looks like it's connected to something you would find in a house thermastat. It looks like there is a bolt holding it on to the intake, but not really sure as it looks rusted over. Would I just remove that bolt then put a new on in?
    Jeremy
    Old 04-06-2012, 05:09 PM   #19
    Hey truckin ,
    If you got the weber 4bbl looks like the choke assembly including the spring is no longer available. I can't remember the part # but I did a electric choke conversion on mine cause I couldn't get the choke assembly.
    Call Edelbrock with your carb # and they will hook you up with a conversion kit.
    Larry
    Old 04-06-2012, 05:11 PM   #20
    voodoo's Avatar
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Yes, although my bolt was rusted in pretty good and broke.
    That spring is the thermostat that activates/deactivates the choke.
    I suggest penetrating oil for a while before doing it.
    sub problems willie1290 Original Mariah Talk 5 07-03-2010 08:10 PM
    Mercruise 3.0L Engine Problems Marci Sadler Mercury MerCruiser 5 05-28-2010 09:26 PM
    Reverse problems markkearns Original Mariah Talk 1 07-08-2009 04:09 PM
    3.0L engine problems pimpadelic Mercury MerCruiser 7 05-16-2009 08:26 AM
    z276mcc has some problems roger Introductions 1 11-01-2007 03:32 PM
    There are 333 users
