Fuel Water Seperator
Old 05-11-2012, 05:43 PM   #1
Juno's Avatar
Juno is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpah 1
Send Juno:
Exclamation Fuel Water Seperator
I am going to install a fuel water separator kit on my 2001 180 Diablo.
My question is since the boat has a full tank of gas in it for storage, when I cut the fuel line will the fuel come flowing out of the tank? Would I be better off pinching the line near the tank and then cutting the line?
Help please...
Cheers
  • Old 05-11-2012, 06:06 PM   #2
    Default Re: Fuel Water Seperator
    I wouldn't expect the line to be under any pressure as you haven't used the boat since last fall. At most i would think there might be a few drops that drain back from the carb as the gas tank is located below where you would mount the separator.
    Old 05-13-2012, 03:31 PM   #3
    Juno's Avatar
    Send Juno:
    Thanks for your response Mikey, I will give it a go
    fuel tank capicity and fuel milage talari z Boating 101 2 08-01-2010 12:01 PM
    Fuel / Water Separator Filter Conversion Dredd Projects 0 04-27-2010 07:30 PM
    water in the fuel jeffro788 Original Mariah Talk 2 04-27-2010 02:32 PM
    adding a water separating fuel filter jeffryb Sea Fox - Mariah Talk 0 01-18-2010 07:57 PM
    Motor operation with water in fuel tank dennis0329 Original Mariah Talk 1 09-21-2009 07:49 PM
    There are 306 users
