sub problems
Old 06-23-2010, 04:27 PM   #1
willie1290 is currently offline
My Model: z252
My Engine: 7.4 bravo III
Send willie1290:
Default sub problems
having trouble getting my subs to work.i have tried 3 different amp got a new head unit put new wires in it used a different sub and it still doesn't work . the amp does get power just doesn't get to the subs. any ideas?
  • Old 06-23-2010, 04:36 PM   #2
    Double D's Avatar
    Double D is currently offline
    My Model: 98 Mariah 202 Shabah
    Send Double D:
    Default Re: sub problems
    Are you coming off your head uint with RCA cables to your amp, make sure there in the output jacks. Double check Ground wire and remote wire to amp.
    Old 06-23-2010, 04:38 PM   #3
    My Model: z252
    Send willie1290:
    yes i am RCA wires the ground and remote wire are all good
    Old 06-23-2010, 05:35 PM   #4
    Hyperryd's Avatar
    Hyperryd is currently offline
    My Model: Shabah 198
    My Engine: 5.7L Alpha
    Send Hyperryd:
    Check the menus on the deck and see if you have to turn the sub output on. Also check the sub level.
    Old 06-25-2010, 01:23 AM   #5
    Hyperryd's Avatar
    Send Hyperryd:
    Any luck with your subs?
    Old 07-03-2010, 08:10 PM   #6
    SuperdaveTX's Avatar
    SuperdaveTX is currently offline
    My Model: Shabah 202
    My Engine: 5.7 Alpha One
    Gallery Images: 8
    Send SuperdaveTX:
    I think you nailed it already!
    Gauge problems mike2828 Mercury MerCruiser 1 11-15-2009 09:46 AM
    Possible Ignition Problems?? Help! jeffryb Original Mariah Talk 3 09-18-2009 12:28 AM
    Reverse problems markkearns Original Mariah Talk 1 07-08-2009 04:09 PM
    planeing problems boat man2 Original Mariah Talk 5 06-05-2009 02:20 AM
    3.0L engine problems pimpadelic Mercury MerCruiser 7 05-16-2009 08:26 AM
    There are 333 users
